Trailer Sway Option
Old Dec 8, 2012 | 10:11 AM
soupy1957's Avatar
soupy1957
Trailer Sway Option
When I was thumbing thru the menu settings in my 2009 F-150 STX SuperCab, I noticed a menu item called "Trailer Sway" (On/Off), which was set to "on."
I knew that the fella who owned my truck before me, towed a trailer (or boat or whatever), so it made sense that it would be activated.
That said, since I don't plan on "towing" anything, I figured that I should (logically) set it to "Off" and did so.
Can someone please tell me if I made the right choice (if not going to "tow" anything)? Is there some advantage in normal driving situations, to leaving that option "On?"
-Soupy1957
Old Dec 8, 2012 | 11:08 AM
MZEMS2's Avatar
MZEMS2
I did the same thing with my '09 a few months ago when I bought it. I left it "on" thinking there might be some advantage. Honestly, I would have a hard time believing that there is an advantage to having it on even WHILE towing. Not much help, I know, but I can't imagine the truck being able to react quick enough to correct something going wrong. Another goofy feature to me.....modern technology. Really not a good way to test it either....hmmmmm
Old Dec 8, 2012 | 11:10 AM
stephen.osborne1's Avatar
stephen.osborne1
I don't think you'd notice any difference unless you tried to tow with it turned off. There is a video out there (made by Ford) showing how the system works to counteract a fishtailing trailer. I believe it became standard on all trucks in '09.
Old Dec 8, 2012 | 12:50 PM
soupy1957's Avatar
soupy1957
Found the video, thanks. I guess I'm wondering if leaving this feature set to "on," would help me or hinder me in the event of a fishtail situation when NOT towing anything.
-soupy1957
Old Dec 8, 2012 | 01:27 PM
PrinceValium's Avatar
PrinceValium
2009 F-150: Towing - YouTube
Old Dec 8, 2012 | 02:47 PM
tvsjr's Avatar
tvsjr
Trailer sway control works with the built-in trailer brake controller... which of course is only active when the trailer is plugged in. So, if you aren't towing, you're fine... if you are, several people who have experienced sway control activation said that it really worked well, so you should probably leave it on.
Old Dec 8, 2012 | 07:46 PM
stephen.osborne1
Not all trucks have the built in brake controller. It works with the traction control on the truck to counteract the fishtail of the trailer.
xzsbkn
2015 - 2020 F150
26
May 6, 2020 05:28 AM
Slavoise
Jun 18, 2017 09:16 PM
Larietpsd
2015 - 2020 F150
Jun 15, 2016 06:33 AM
383lightning
19
Feb 6, 2013 12:13 PM
N_fini_T
All Things Towing
Mar 15, 2003 06:06 PM
