Rotor help/suggestions
Old Dec 9, 2012 | 02:08 AM
FordTruckEnthusaist's Avatar
FordTruckEnthusaist
Haha, well I just put a new set of BFG all terrains on 3k miles ago. But I will have them rotated and balanced in 1.5k miles or so when I change my oil.
Old Dec 9, 2012 | 09:18 AM
rattleNsmoke's Avatar
rattleNsmoke
I replaced a warped set of factory rotors with the slotted Raybestos from www.rockauto.com. The pricing and delivery was good and no more pedal pulsation.
Mike
Old Dec 9, 2012 | 11:13 AM
hughball65's Avatar
hughball65
So far, truck has new brake pads, new shocks, and new tires... many possibilities.
When the new brake pads were installed, did the installer, for some reason, remove and reinstall the brake lines without bleeding calipers?[pulls hard left or right when braking].
I would try bleeding front calipers first... then go from there.
As for vibration without braking... new tires installed, and am under the impression that the vibration didn't exist prior to new tires... could have a bad tire on front(warranty) or a bent wheel from rear that is installed on front now.
As a starting point, try rotating fronts to back/backs to front and see if that makes a difference.
Old Dec 9, 2012 | 12:41 PM
FordTruckEnthusaist
Thanks rattle for you're input, was hoping to hear from someone who has tried them.
I'll try doing that when I rotate tires and see if that does anything. If it were that a wheel was bent or something, wouldn't that of showed up a long time ago? All this vibration is fairly new.
Old Dec 9, 2012 | 01:16 PM
the_auto_tech's Avatar
the_auto_tech
Originally Posted by berick
If you do end up having to buy new pads and rotors...... stay away from EBC's GD rotors and Yellow-stuff Pads. Overpriced, lousy service and a bit noisy..... not to mention their fitment charts and supposedly knowledgeable staff are awful.
They shipped me the wrong size front rotors initially.... took close to 1-1/2 months to get them.... then went to put everything on and they also shipped me a set of damaged front pads.... which I had to wait another 2 weeks to get. Not a good thing when your brakes are down to the wire.
oh yeah...... they do not brake any better and they have a squeal even after the break-in period.
EBC is the bomb on ATV applications but as far as automotive goes, I will NEVER waste my money on their product again!
I will agree with you on a lot of these points. Their fitment charts and customer service do suck. I bought the EBC 3GD rotors for my S4 and got sent ones that were just cross-drilled and they were both for the right hand side. I was told I could just keep them and they would send me the proper set. 5 months later I still didn't have the correct ones and ended up getting my money back. I will likely go with Centric rotors next time. I've always been a fan of Hawk pads though. In fact, I need new rear brakes on my PSD, so I've been wondering myself who to go with.
Old Dec 9, 2012 | 01:19 PM
strokinpower's Avatar
strokinpower
On the Super Duties there is no better pad or rotor than the factory motorcraft.
Old Dec 9, 2012 | 01:23 PM
hughball65's Avatar
hughball65
Depends on how slight the bent is... may not have been noticable so much on rear than front... see what happens after rotating... if same vibration is still there, then you've eliminated wheels/tires and can move on to other causes...
Rotor problems tend to show themselves during braking... not leaning torwards them for your vibration problem.
Old Dec 9, 2012 | 01:56 PM
FordTruckEnthusaist
Would it be safe to say I probably do need new rotors, and possibly there are other things wrong too? It does seem to shake more when I am braking, especially from higher speeds, and every once in a while it jerks left to right real quick.
Old Dec 9, 2012 | 02:25 PM
hughball65's Avatar
hughball65
Shaking more when braking and pulling left or right real quick when braking more agressively would indicate warped rotors... but not the vibration when not braking, unless your calipers are sticking.
Did your mechanic use caliper grease on the slide pins and where the brake pads sit in the caliper when new pads were installed? Did mechanic remove brake lines and not bleed afterwards?( though I cannot see a reason why someone would remove the brake lines to change pads).
Non braking vibration could be a bad tire... thus suggestion to rotate and see if problem moves.
Many possibilities...
Old Dec 9, 2012 | 02:56 PM
FordTruckEnthusaist
I'm not really sure what he did with the calipers, or if he did anything. I guess I'll ask him when I take it in.
So I guess to start with, I'll replace rotors with some slotted and drilled Raybestos, I'll have him check out my calipers and what not, and balance and rotate my tires and see if that changes anything. If not, I guess I'll go from there.
Does this sound like a solid plan?
Old Dec 9, 2012 | 03:14 PM
hughball65's Avatar
hughball65
Sounds good... be sure and let your mechanic know of your symptoms and when they arose as "he" will be the one actually putting his eyes, hands and experience on the problems test driving for "himself".
Keep us posted.
Old Dec 9, 2012 | 03:37 PM
Piolet's Avatar
Piolet
Originally Posted by FordTruckEnthusaist
What are the effects of having warped or damaged rotors? I have quite a bit of vibration, and sometimes when braking my steering wheel will jerk real hard left or right.
Important to be exact here. Will the steering wheel jerk either direction?
As cheezit mentioned above, usually a stuck caliper pulls the truck towards the stuck caliper when driving without braking, but pulls it to the opposite side when braking. That there is a good test on its own.
Stuck calipers if clamped on the rotor can be a bear to remove. Once the caliper is removed any stuck slide pins are obvious.
To check for an issue with the rotor, after you take off the wheel reinstall 3 of the lug nuts to secure the rotor back in place properly. Rotate the wheel by hand and listen to where it rubs against the brake pads if there is a high spot. Mark the rotor with a crayon at that spot and the nearest lug nut too.
Remove the rotor and reinstall it but at about 180* difference from first position. Reinstall 3 lug nuts and spin it again. See if the new high spot has followed the crayon mark on the rotor or if its still at the lug nut. If it's followed the rotor mark then the issue could be in the rotor. If it's still close to the marked lug nut then inspect the hub area for dirt and rust high spots and clean down as necessary.
Old Dec 9, 2012 | 04:38 PM
  #28
FordTruckEnthusaist
It's only jerked real hard left and back right twice, but both times if I can remember right it was from left to right while braking. Whenever I'm just driving, it doesn't seem to pull to either side more than the other, it just vibrates, and when I hit a bump it almost always seems to jerk around a bit. I don't know, it's hard to explain over a computer, haha.
And I'll keep everyone updated. May be a week or so, gotta get paid before I spend 400+ on some rotors
VTENX
May 28, 2015 03:33 PM
MilllerTime
2004 - 2008 F150
Dec 27, 2013 05:07 PM
BAJI26
Apr 23, 2011 12:32 AM
Vankaye
Jul 23, 2007 10:03 AM
celjel
Oct 14, 2005 10:09 AM
