Pulsating When Braking
Old Feb 23, 2010 | 12:16 AM
BAJI26's Avatar
BAJI26
Hawk LTS and Powerslot Cryo's
I have a pulsation in my pedal and steering when applying brakes.
The steering wheel rocks from left to right.
I changed the sliding pins on both fronts.
What should I do next?
I'm tired with it right now and thinking for looking for a 2005 4WD or a Expedition XLT or somthing else cause it pissing me off... Thanks!
Old Feb 23, 2010 | 12:49 AM
Monsta's Avatar
Monsta
Sit. Stay.
Try tightening your spindle nut(s). You know...the ones holding on the front bearings.
Old Feb 23, 2010 | 01:12 AM
Adrian Crook's Avatar
Adrian Crook
Pulsing is usually warped brake rotors, isn't it? I know I just got my front rotors replaced (they were cracked and warped, causing the pulsing when applying brakes) and the problem is gone completely.
Not sure why your steering would be affected though - perhaps your rotors are more severely warped?
Old Feb 23, 2010 | 02:54 AM
Stewart_H's Avatar
Stewart_H
They aren't actually warped, but the surface is uneven due to hot spots creating cementite from uneven pad transfer. The problem is usually described as a warped feeling though.
Be that as it may, the OP has already swapped out the problem rotors and replaced them with cryo treated Powerslots. Cryo treated rotors are the permanent solution to the problem described as a warped rotor.
Baj, I had this happen to me on my Excursion back in May of '08. I too was perplexed at the time because I'd been running the Cryo treated Powerslots and Hawk pads for quite some time without a problem (nary a wiggle at all) when slowly but surely the shimmy came back. It turns out the inside face of the passenger side rotor needed to be resurfaced because my hub failed. The hub created a depression in the rotor, as well as the brake pad. The pad was sanded flat, the rotor was brought back to true on the lathe, and the hubs were replaced and everything has been perfect ever since.
Stewart
Old Feb 23, 2010 | 05:22 AM
katiesdad7's Avatar
katiesdad7
Could it be the rotors are dirty/oily and that is causing it? Maybe just some brakeclean?
Old Feb 23, 2010 | 09:23 PM
BAJI26's Avatar
BAJI26
I will tighten the Bearing Nut, if that doesn't help I will take it to the brake shop and see if resurfacing will do any good... Thanks!
Old Feb 23, 2010 | 10:55 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
That's exactly what it was when I replaced my front rotors...
They were initially too loose, then too tight, then just right...
Make sure and pack those hubs tight with grease!
Old Feb 24, 2010 | 12:22 AM
ke6zmy's Avatar
ke6zmy
There is a lot of information out there about this. Particularly regarding the Excursion. Mine is an 03 limited w/ a 7.3L.
I learned that the rotors get "hard spots" in the metal of the rotor. Similar to what Stewart_H said. If you have the rotors turned (machined) the hard spots shall be cut down to the same level as the surrounding level. Unfortunately, as the rotors are used the hardened metals wear differently from the surrounding, softer, metal. It is not long, under 500 miles, and you are back where you started. Pulsation as you apply the brakes that is transmitted up through the steering column.
My solution was to purchase Royalty Rotors drilled and slotted rotors and new pads. No more problem. In fact, I have found that they provide better stopping power in water.
I am very happy not having the pulsating. I am more happy not having the Mrs. telling me to "Do Something" about it.
I suggest that you consider drilled rotors. Frozen or not. Get the ones that have chamfered holes.
Old Feb 24, 2010 | 01:22 AM
delzy's Avatar
delzy
I found a shop that turned my front rotors on the truck for about $86. The problem has been gone for 2500 miles. These 2wds sort of suck for rotor replacement because you have to replace the whole hub. It's a lot more work than just throwing a new rotor onto the hub like on the 4wd.
Old Feb 24, 2010 | 08:04 AM
Mante's Avatar
Mante
I have had this experience with glazed rotors.. driving to hard without proper bedding of the pads.
Old Mar 21, 2010 | 03:42 PM
BAJI26's Avatar
BAJI26
Finally got the brakes where it was when I first installed the Powerslot Cryo Rotors.... I got then resurfaced and now it feels sooo smooth.
Next problem is the ball joints, how difficult it is to change them and what tools do I need?
Both upper and lower need to be changed!
Where can I get the best priced Moog with the nipples?
Thanks!
BAJI26's Avatar
BAJI26
Thanks!
Old Mar 21, 2010 | 07:28 PM
Landbarg's Avatar
Landbarg
Thanks!
Ball joints are easy if you have the right tools. You will need a heavy duty ball joint tool and a good air compressor with an impact gun. A larger sized socket set (22mm and 24mm) to get the nuts off. I got my Moogs from Advance Auto for $200.00
Old Mar 22, 2010 | 12:07 AM
tacurt's Avatar
tacurt
I'm having the same issues, but I just got the truck a month ago. Are the powerslot rotors really worth the price? I was looking at getting napa premium rotors for $150 each.
Old Mar 22, 2010 | 12:24 AM
Stewart_H's Avatar
Stewart_H
They are to me.
I put the cryo treated Powerslots (not the regular Powerslots) on my Ex a few years ago. Just recently, when my F250 needed front brakes, I never even considered anything else, just the cryo'd rotors.
Stewart
