Sponsored by: Auxito
brake light
Old Dec 7, 2012 | 02:24 PM
bashby's Avatar
bashby
brake light
98 F150. Failed inspection for the dash brake light not coming on when you turn the key on. It comes on with the park brake set. Should it come on with key on as a bulb test?
Old Dec 7, 2012 | 02:37 PM
LucasMN's Avatar
LucasMN
My 02 does.
I kinda wish MN had inspections. Would keep a lot of "minorities" and their clunkers/unsafe vehicles off the road.
Old Dec 7, 2012 | 03:45 PM
bashby's Avatar
bashby
My next obvious question, how do I fix this (non)problem?
Old Dec 7, 2012 | 05:20 PM
blue2golf's Avatar
blue2golf
If the light comes on with the PKB engaged, that would be good enough for me. However, you are dealing with "The State" and they have a different set of rules. Given the thousands of F150s that pass your state inspection each year, prehaps it should be lighting up as required.
Ask the inspecting station if they've seen this type of failure before and what was done to remedy it. Maybe call your local Ford dealer too.
Worst case, new instrument cluster prehaps?
Old Dec 7, 2012 | 06:00 PM
Lime1GT's Avatar
Lime1GT
According to my information on a 1998 F150; Brake warning light should only come on when ignition switch in Start position or ignition is on with parking brake applied or fluid level low. On diesel vehicles brake light should also come on when vacuum is low.
Old Dec 7, 2012 | 06:09 PM
projectSHO89's Avatar
projectSHO89
The criteria for pass/fail should be readily available from the state agency responsible for the administration of the safety inspection program. For example, in Missouri, it is run by the highway patrol.
From looking at the schmematics:
On a 98 F150 with RABS-only, the red BRAKE light is supposed to come on in the START position but not the RUN position, as a bulb self test. If you have 4WABS, it should come on in both START and RUN.
Old Dec 7, 2012 | 07:55 PM
bashby's Avatar
bashby
This truck has rear antilock only. I don't think it came on with the switch in crank either... I'll have to look into that.
Old Dec 7, 2012 | 08:37 PM
Spotty's Avatar
Spotty
My 98 is RABS only, and I just went out and tested it....yep...no light in run, but pops on when in start position. I had a lot of problems with the brake light and RABS yellow light being on and off randomly. I read up on how to pull the anti-lock codes and it turned out a pin was rusted inside a connector on the RABS unit under the master cylinder. The rust on the whole unit was unreal. Got when at the bone yard for $20 bucks....just like new again...
oldbird1965
25
Jan 24, 2014 10:01 PM
labman1014
Nov 5, 2012 04:07 PM
Confederate Diesel
Jan 4, 2011 10:14 PM
battleriver
Jul 23, 2006 02:29 PM
elstx
Electrical Systems/Wiring
Dec 28, 2003 05:28 PM
