Brake light in cluster
Old Nov 5, 2012 | 10:43 AM
labman1014's Avatar
labman1014
Well my brake light won't come in with the key or parking brake. I pulled the cluster to change a bulb and the brake light bulb was good. So I swapped it with the door ajar light that I knew that worked. Well brake light still isn't working and the door jar light still works.
So what do I need to check to find out why the brake light isn't working?
Old Nov 5, 2012 | 11:23 AM
TXtinct's Avatar
TXtinct
You'll shoot your eye out
Does your brake work? There is a little wire that attaches to the top of the brake assembley. You may want to make sure it's plugged in. That's all I got.
Old Nov 5, 2012 | 02:01 PM
labman1014's Avatar
labman1014
Yes I checked there but I can't even get the light to come on when they all test with the first turn of the key.
Old Nov 5, 2012 | 04:07 PM
ufvj217's Avatar
ufvj217
mine sometimes does and sometimes doesn't show the "BRAKE" light when i start the car with the E brake on. sometimes when it doesn't show, i forget its enabled until i start to drive off lol. ill check that plug on the top of the brake on mine, didn't think about looking. i bet its loose.
boybowser
20
Dec 22, 2017 05:58 PM
battleriver
Jul 23, 2006 02:29 PM
pbuehning
Oct 16, 2004 10:13 AM
idealtrucks
Nov 27, 2002 12:42 AM
