ScanGauge II denier
12-19-2012, 07:04 PM
Not sure which delete you have, most use hose clamps on that hose, a new OEM probably will not work any way.
So, no, I would guess not.
12-19-2012, 07:23 PM
yes oem will work the best
and yes you need that hose even with egr deleate
Is it already deleated?????????????
12-19-2012, 07:27 PM
Quote:
Originally Posted by
BLADE35
I have a blue hose coming off the back side of that oil cooler cap that I remove to stick the 3/4 inch hose into.
12-19-2012, 08:06 PM
BLADE35
Do I need to replace that hose before or after the flush? Also, the o-ring replacement I understand. Why does the hose need replacing?
12-19-2012, 10:27 PM
DieselVol
I am really thinking you do not need to "replace" the hose you already have, unless you think it is having issues.
I probably
should not have left the Hose # in the list. My fault.
12-19-2012, 10:33 PM
amdriven2liv
I probably should not have left the Hose # in the list. My fault.
Thanks, and no problem. I'll just get the o-rings. As an update, I got to break away for a hunt yesterday and the delta on the interstate run ran 16-17 most of the time. The problem seems to be progressive...
KK560
2009 - 2014 F150
11-04-2018 09:43 PM
86cherokeek20
11-26-2011 11:14 PM
tk1251k
Aerostar
19
01-22-2008 08:00 AM
caseydudem
21
01-15-2008 07:14 AM
dande
1997 - 2003 F150
11-03-2006 10:06 PM
