FYI if you have code 1211
My truck intermittently went into idle while driving and I could not figure out the problem to save my life. I checked the fuel filter and it looked fine. I was about to go after the HPOP and ICP but a buddy said he would check the fuel filter again. I went ahead and replaced it and it started right up and has been running great since. I turned out that a sludge that was the same color as the filter pleats had built up and I couldn't tell it was clogged by raising it up a little out of the canister. Hope this helps anyone else with the same issue.
Update:
Truck ran well for 5 days, no 1211, and then it started up again. I got a cheap fuel pressure gauge from Harbor Freight just to rule it out and it read 20 PSI at idle. I'm thinking this has to be it. Nope. Gauge was bad. So after spending $100 and a couple of hours on a new fuel pump, I'm right back where I started. I'm thinking this has to be oil. I don't want to throw parts in it anymore, so I might just take it in to have it diagnosed with a full scanner.
