6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Fuel problem
Old May 18, 2012 | 02:27 PM
Kidscreations's Avatar
Kidscreations
Fuel problem
I have a 2009 F-250 King Ranch with 107,000 miles. The truck looses all power driving down the road (60 mph top speed). Have to turn the truck off and restart and it will run fine. Sometimes for days sometimes for 5 minutes. Took to the Ford Dealer and the code shows high pressure fuel bypass (or something like that). Mechanic recommended buy some Hot Shot Fuel Additive and see if that fixed the problem. Have ran 3 tanks of fuel with the Hot Shot added. Still have the issue. The mechanic was very adamant that this would fix the problem.Any other suggestions before I shell out $2,500 for a new injector pump?
FYI: It seems like the hotter it is outside the more frequently the issue.
Thanks in Advance.
Old May 18, 2012 | 05:27 PM
senix's Avatar
senix
Ever change your fuel filters...I would assume so.
Probably cannot getting around the issue.
What code and did you take it to ford or someone else?
Old May 18, 2012 | 06:35 PM
Kidscreations
Yes, I change fuel filters regularly. I took it to the Ford dealer where I bought it. They are the ones who ran the diagnostics. The code they said was the high fuel pressure bypass. They said it was sticking open. That is why they thought the Hot Shot would work.....but to date has not.
Today I poured some Hot Shot in with the upper fuel filter. I guess we will see what that does.
Old May 18, 2012 | 08:08 PM
Tom's Avatar
Tom
Here's hoping it has good lubricity, as dumping that much of anything other than fuel in the secondary fuel filter seems a bit dangerous to me. Here's hoping that if you don't have a bad HPFP this doesn't cause any damage.
scottz99
Feb 15, 2016 07:22 AM
stevorino
Dec 16, 2012 11:18 PM
Kidscreations
May 18, 2012 02:24 PM
jhkfarms
13
Jul 21, 2009 06:30 PM
jmapes38
May 24, 2009 10:04 AM
