Pinging?
Old May 23, 2003 | 11:14 PM
John with beastly 302's Avatar
Pinging?
Hey,
My F-150, (see signiture), makes a real heavy pingin noise when ever I'm going about 60 to 70 on the freway in 3rd gear and doese it at 65 when pulling a horse trailer in 3rd gear. I exclusivly use Chevron gas. Oh and also it stoped making the noise after about 15 miles. So what do you guys think Put some techron concentrate in or is it mechanical.
John
Old May 24, 2003 | 12:59 AM
LxMan1's Avatar
LxMan1
Pinging?
Could be a sticking EGR valve causng a lean condition which would make it ping. It's not lifter noise is it?
Jimmy
Old May 24, 2003 | 09:59 AM
Pinging?
No its not lifter noise because when it revs up in 1st or secong it dosnt make the noise just when its going in third at a high speed under a load. It will also make the noise when your floor it and right at the point it shifts from third fourth. It only seems to do it when you really step on it in third but dosent when you dont floor it all the way through third.
Old May 24, 2003 | 12:26 PM
Mil1ion's Avatar
Mil1ion
Pinging?
Retard the timing a "fraction"
Old May 24, 2003 | 06:21 PM
Pinging?
How can I when everything is electronically controlled?
Old May 24, 2003 | 07:07 PM
Mil1ion's Avatar
Mil1ion
Pinging?
Got me there !
I read way too many threads.
Old May 24, 2003 | 07:17 PM
Bob Ayers's Avatar
Bob Ayers
Pinging?
John,
I see your running a K&N air filter. It is possible that your MAF
sensor has been contaminated with oil, which will cause a
lean condition. Try cleaning your MAF, and if you want my
opinion, throw that K&N filter in the trash......The K&N will
also let dirt into your intake that will be caught with the OEM
paper filter.
Old May 24, 2003 | 09:19 PM
steve83's Avatar
steve83
Pinging?
Originally posted by John with beastly 302
How can I [retard the timing] when everything is electronically controlled?
The position of the distributor isn't electronically controlled . It can be rotated just like a carb engine's. But I'd advise keeping it and everything else set to factory spec according to the instructions on the emissions sticker in the engine compartment.
I love my K&N - I'll never go back to paper.
jrollins
Jan 4, 2013 10:13 PM
pf350
Oct 31, 2011 02:30 AM
93f1505.0L
Mar 12, 2007 10:39 AM
snipa
Sep 30, 2005 11:10 AM
acerockola77
Feb 3, 2004 09:28 PM
