Clutch issue
Old Jan 4, 2013 | 09:14 PM
jrollins's Avatar
jrollins
Clutch issue
I have a 1999 f350 dually 7.3 standard transmission. The clutch pedal is soft and I can't get it to go into gear or out of gear. I had to force it into 3rd gear to get home. When at a stop light and the clutch pedal all the way to the floor, the truck will start to move when I release the pedal about 1/2-1 inch from the floor not enough to get it into the next gear or out of the existing gear. So is my problem the clutch or the one piece hydraulic system that consist of reservoir then goes to the clutch pedal and to the transmission. Please Help!
-John
Old Jan 4, 2013 | 09:33 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
How did it happen? If this is an "out of the blue" failure I would suspect the hydraulics. If it's been a gradual thing I'd guess your early clutch fork is bending.
Old Jan 4, 2013 | 09:39 PM
jrollins's Avatar
jrollins
Gradually been getting worse. Is the clutch fork something that usually goes out? Is this something that is easy to replace? I have changed the clutch and hydraulic system in the past with ease. Where is the clutch fork located?
Old Jan 4, 2013 | 09:41 PM
jrollins's Avatar
jrollins
Also, this problem started all of a sudden and then gradually got worse. It didn't leave me on the side of the road. From one day to the next the pedal felt softer.
Old Jan 4, 2013 | 09:49 PM
timmyboy76's Avatar
timmyboy76
Was fight'n clutch problems for awhile. Broken peg on pedal, blew out the slave, clip broke on master.... I say, start with the master/slave assy. Dont tool around with replacing one or the other. If theres an Advance Auto near ya, go there. They have the assy in all aluminum, if not, your local auto parts store, is the next best thing.
Advance Auto = PF9021
or Amazon...
Perfection Clutch PF9021 Clutch Master and Slave Cylinder : Amazon.com : Automotive Perfection Clutch PF9021 Clutch Master and Slave Cylinder : Amazon.com : Automotive
Here's a link about the write-up...
Upgraded hydraulics for ZF6 transmission [Archive] - PowerStrokeArmy
Clutch fork is located inside the bell housing...
Old Jan 4, 2013 | 10:13 PM
jrollins's Avatar
jrollins
Hey timmyboy76, thanks for your help! John
runner
Jan 3, 2023 11:03 AM
Lloydable
Dec 19, 2015 10:00 AM
dlsmithsr
Mar 3, 2011 01:30 AM
MadFrank81
General Automotive Discussion
Nov 5, 2010 12:23 AM
sethro
1983 - 2012 Ranger & B-Series
Oct 15, 2002 02:03 PM
