Turn signal switch
Old Dec 5, 2012 | 06:57 PM
rustydailey's Avatar
rustydailey
Turn signal switch
I'm having troubles with my turn signal. Whenever I turn them on I have to turn the wheel to get it to catch and stay on. How do I get the wheel off to change/fix it? Do I need a wheel puller, or is it like a chevy?
Old Dec 5, 2012 | 07:12 PM
AzPete's Avatar
AzPete
Does the wheel sit straight across when you are going straight down the road? If it is not straight, it may be alignment or steering issues.
Old Dec 5, 2012 | 07:45 PM
rustydailey
No it's definitely an issue with the switch. The wheel is straight and I've had this problem since I bought the truck and have had it aligned and it did the same thing.
Old Dec 13, 2012 | 08:03 PM
rustydailey
I can't believe that no one has had to remove their steering wheel or replace the turnsignal switch.
Old Dec 13, 2012 | 08:58 PM
mueckster's Avatar
mueckster
You don't have to remove the steering wheel, only the cover behind it. Separate the two halves of the cover and you will see the screws that hold the switch to the column.
Old Dec 14, 2012 | 07:10 AM
theenforcer's Avatar
theenforcer
mine does the same would like to know how you went rusty..
Old Dec 14, 2012 | 10:20 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
I'd try cleaning it or fiddling with the connections first. Multifunction switch is over $100
Old Dec 14, 2012 | 11:01 AM
theenforcer
i find mine clicks off when i turn the wheel slightly the opposite way to the way im indicating, for example, when entering a round about if im indicating right when i steer left at the start before i steer right to go round the roundabout it will click off and i have to wait untill i have started turning right to click it back on, im used to it but it is a bit of a PITA. would be nice if it didnt do it. are the screws that hold the switch to the column located in elongated holes making it possible to change position of the switch for a easy fix. if anyone knows it would save me a morning of tinkering..
cheers guys
josh
gogreenwave
Jan 22, 2018 08:51 AM
toofazt
Sep 22, 2012 05:48 PM
sddesigns
Sep 28, 2008 09:41 PM
86fn150
Feb 9, 2008 11:54 AM
Gold Winger
1997 - 2003 F150
Jan 2, 2004 11:50 AM
