Turn Signal Switch
Old Sep 10, 2008 | 09:15 PM
sddesigns's Avatar
sddesigns
FTE Leadership Emeritus
FTE Emeritus
Question Turn Signal Switch
I have a 2001 4X4 EX V10 and my turn signal won't stay on, Is there a way to adjust the turrn signal switch, when I have the steering wheel slightly turned it won't stay in either left or right position without straightening out the steering wheel or turning it further than needed to turn?
Old Sep 16, 2008 | 01:41 AM
Monsta's Avatar
Monsta
Sit. Stay.
Ya know...I don't know how to adjust that or if it even can be. Never pulled it apart to look. Sorry...
Here's a bump to the top, though.
Old Sep 28, 2008 | 09:41 PM
sddesigns's Avatar
sddesigns
FTE Emeritus
Found Solution to Problem.....
Figured out the turn signal problem, the steering wheel centering adjustment.
https://www.ford-trucks.com/forums/7...with-pics.html
Becuase the steering wheel was slightly turned to the right (about 1") it was enough to affect the turn signal engaging and staying on without slightly adjusting the direction of the steering wheel.
Thanks Quietman for your outstanding post...
