Possible E-series 5.4l defect
Old Dec 4, 2012 | 11:06 PM
ward107's Avatar
ward107
I posted a picture on an issue I had with my 2005 e350 with a 5.4l having miss fires and no start issue and found a burnt spot on the wire harness off of the PCM. I did have occasional hesitation on left turns for quite some time. The thread is located in the Econoline area. If you have the same engine I would check that spot for wear and try to move the harness away from the exhaust component. Repair from the dealer is in the upward of $4000.00 with a blown PCM. I went with a PCM 150.00 and I am repairing the bad spots of the harness. Only 1 PCM matched mine in OHIO.
https://www.ford-trucks.com/forums/1...st12552145vage
1Fastboy
Computer Chips & Tuners
Dec 21, 2020 10:52 PM
kegomatix
Escape & Escape Hybrid
Jun 7, 2017 11:15 AM
SkySkiJason
Apr 17, 2010 07:31 PM
genbryan
Mar 5, 2009 08:19 AM
