It's a big motor with high compression and it takes a lot of power to turn it over to start it. Even the 5.2 four cylinder Isuzu oil burner I drive at work has two batteries.
The batteries are wired in parallel but as others mentioned, Ford considers the passenger battery the primary.
That's where I pull power from when needed (such as my viair air compressor).
