Vehicle monitor.
Old 12-28-2012 | 06:19 AM
mustang_309's Avatar
mustang_309
The FICM main power is the one you need to watch all the time 48 volts is ideal. If at any time it drops below 45 volts the FICM needs to be repaired.
Old 12-28-2012 | 11:47 AM
Stroker 6.0 fan's Avatar
Stroker 6.0 fan
Thanks for the info.
Old 12-28-2012 | 12:18 PM
Misky6.0's Avatar
Misky6.0
Originally Posted by Stroker 6.0 fan
My wife is the reason for the back up camera which is why I was thinking of the Edge. I love her to death but, she can not back up to a trailer to save her life. lol. I'm actually leaning towards the Scan Guage II. Does this one also monitor oil and engine temp as well as voltage?
A backup camera isn't going to help.....
We have a large field with lots of dandelions on our land with a dirt road
down the center.
My wife once backed up our Jeep TJ about 300 yards (NO trailer).
She was off both sides of the road at various times.
When I got in, I said "you missed a few dandelions do you want to try again?"
Even she thought that was funny.
Old 12-28-2012 | 02:19 PM
Stroker 6.0 fan
Thumbs up
Thanks for all the good info on here. Hopefully this will be my last question on this subject. I have one of my gauges set for EOT-Engine oil temp. Anyone have an optimal rage I should be looking for? Also I can not seem to find an e gauge for ECT-Engine coolant temp? Is there one for the scan gauge and if so do I need to have an additional sensor? Thanks
Old 12-28-2012 | 03:32 PM
Misky6.0's Avatar
Misky6.0
I think its fWT for F* Water Temp. The newer units also come programmed
for ECT I believe - but it's easy to program in...
Once your cooler temp gets to 190 the oil temp should be close behind.
Under normal conditions (not towing, flat terrain) highway speeds the coolant
should be about 190, and oil temp should be LESS than 15 ABOVE the coolant temp.
If your coolant stays < 184-ish your t-stat is bad (or you are in Northern Alberta with cold temps)
Old 12-28-2012 | 09:23 PM
Stroker 6.0 fan
Thanks for the info. I did find the coolant temp gauge. I was looking for ECT instead of Fwt. I got my four gauges going this is what I averaged today on normal highway and city no tow. FWT188-190 EOT 190-193 VOLT 13.1-13.6 FICM MAIN POWER 47-47.5
mugsaway
2004 - 2008 F150
03-04-2010 08:53 PM
barnbridge
07-23-2009 10:16 PM
Fordfrog206
2004 - 2008 F150
04-08-2007 02:54 PM
HOTFOOT
04-14-2006 07:45 AM
PSD6litre40
02-13-2005 06:15 PM
Quick Reply: Vehicle monitor.
