P0236 code?
Old Dec 5, 2012 | 07:14 AM
brad7.3's Avatar
brad7.3
So the fpr is behind the "pipe plug" looking thing on the side of the fuel bowl? So should I take that plug out and inspect it, or just get a new one and put it in?
Old Dec 5, 2012 | 09:04 AM
Action4478's Avatar
Action4478
Info & pictures ...here http://www.dieselorings.com/docs/OBSFuelBowlRebuild.pdf
Old Dec 5, 2012 | 09:55 AM
brad7.3's Avatar
brad7.3
That is great, thanks!
Old Dec 5, 2012 | 09:23 PM
brad7.3's Avatar
brad7.3
So when I get a chance to check out the fpr, do I have remove the whole fuel bowl, or can I just remove the fpr?
Old Dec 5, 2012 | 09:59 PM
Action4478's Avatar
Action4478
You can just remove the FPR if you wish ...
Old Dec 7, 2012 | 04:32 PM
brad7.3's Avatar
brad7.3
Would it be a good idea to pull the whole fuel bowl to mess with the fpr? If I pull the bowl, is there gaskets/o-rings that I'll need to have, or replace? Any thoughts? Looks like pulling the bowl would make replacing the ipr a lot easier.
Old Dec 7, 2012 | 07:49 PM
brad7.3's Avatar
brad7.3
Ok, so I went ahead and pulled the bowl. I won't know for sure until I clean it, and put it all back together but, I don't see how anything could get past that little screen, there is about a 1/8" thick layer of crap on it! So I'm gonna go tear it all apart and check out the inside of the fpr also. I'll probably change out the ipr before I put the bowl back in, I bought one last fall but never got around to changing it out. Can I get the couple o-rings for it at my local parts store? I'll let you guys know how it turns out.
Old Dec 7, 2012 | 07:55 PM
427 fordman's Avatar
427 fordman
This is a link to the kind of orings you need to use. I don't think you'll find them at the parts store.
Riffraff Diesel: Complete OBS Fuel Bowl Oring Kit
Old Dec 7, 2012 | 09:09 PM
brad7.3's Avatar
brad7.3
Right on, just ordered a set. That's a drag though, gonna be the middle of next week before I got them.
Old Dec 9, 2012 | 07:56 PM
brad7.3's Avatar
brad7.3
You guys are the best! I pulled my fuel bowl, cleaned the fpr, which was unbelievably plugged with crap, changed
ipr, I Just got back from the test drive and Ol' Smokey runs better than it has in years! No cel, no missing, it even idles smooth now, no loping! This thing has had that damn 1211 code now for 2 years, can't believe it didn't come on pulling out of my driveway when it hit second! Thanks again fellas!
Old Dec 9, 2012 | 09:45 PM
oldbird1965's Avatar
oldbird1965
I like success stories!!
SLAMMIN 22
May 23, 2011 07:34 PM
Bordercollie61
Oct 3, 2010 01:23 PM
fordtuff125
Nov 24, 2008 06:19 PM
Ford_Raised
17
Oct 16, 2008 02:02 AM
kbeefy
Jul 25, 2006 09:36 PM
