HELP
Old Dec 2, 2012 | 10:33 PM
sglass57's Avatar
sglass57
HELP
My 2000 f250 won't stay running it keeps draining the batters I have changed them and the alternater but the intake heater relay was burnt up and so was the wires going to it were burnt up so I took the relay off is that bad some one told me that I don't need it but it is still draning the batters I need help any help will be great
Old Dec 3, 2012 | 05:39 AM
bcaughhorn's Avatar
bcaughhorn
no you do not need the iah. you can disconnect one battery and unhook one cable from the other and hook a test light to the post to the clamp. it will light up. start pulling fuses one at a time until the light goes out. when you find the rite fuse you will know what circut is draining the batteries
Old Dec 3, 2012 | 09:24 AM
Shake-N-Bake's Avatar
Shake-N-Bake
I would suspect the IAH and/or Glow plug relays are stuck in the on position and draining your batteries. Burnt wires going to the relay is a clue that something is very wrong with those systems.
Old Dec 3, 2012 | 12:21 PM
sglass57's Avatar
sglass57
Thanks for the help
Old Dec 5, 2012 | 06:37 PM
sglass57's Avatar
sglass57
Ok I tried taking it off all together and it still keeps dying there are no shorts any where. Could the wires just being took off still kill the batters?
Old Dec 5, 2012 | 07:07 PM
sand_fiend's Avatar
sand_fiend
Take your battery's and have them Load tested. one battery probably has a dead cell and is draining both. It dose happen often when one go's bad. sometimes It will show 12 V by just doing a test. that's why it needs to be a load test.
it's a good chance the short and battery drain killed off a weak battery, you can NOT test both at the same time. you need to do EACH Separately.
Old Dec 5, 2012 | 07:51 PM
sglass57's Avatar
sglass57
Well we hocked a volt neater up the the alternater and it was 0
dougbrown
Mar 29, 2014 05:15 PM
utahxjer
Dec 10, 2013 08:49 PM
plwilliams
Aug 20, 2010 02:30 PM
rmilchman
Nov 2, 2009 09:47 AM
jiggersup
Sep 15, 2009 07:16 PM
