Hello...I am new to these forums and I have had the same problem with the O/D Off light flashing. I drove it about 3 or 4 miles with the light flashing. I pulled into an empty parking lot and read the owners manual. It said turning the engine off and turning it back on resets the O/D to on. I did that and the flashing stopped and stayed off all the way home. (About 10 miles) I had no issues with the transmission or RPM's. Everything seemed normal.
You can check the gear column for exposed cable .
Or take it to the dealer to fix it . I did everything that I could think off but the problem still . So the truck now at ford service center .
Finally I got my truck and running good , flashing gone, smooth shifting, .
The problem was the harnesses from the transmission and the abs sensor harness.
Thank you guys for helping .
I'm glad you got it fixed!
This is from the third post in this thread:
Originally Posted by Mark Kovalsky
Now you need to check the wiring between the sensor and the PCM. Any problem with the wiring, either open, short to power, or short to ground, is going to cause P0722 and P0720. Same for the wiring between the vehicle speed sensor on the rear axle and the PCM, and the P0503 code.
I know that and I considered and I let the mechanic see your posts .
Thank you Mark .
Not surprising.
Go anywhere for help and give them info off the web and you instantly loose credibilty. I fix network issues, i still start at the beginning even if you tell me your isp checks out ok..
Not surprising.
I told him because he asked me what happened and what do I fix or replaced or checked , Before I went to them . And he checked every thing all wires , connectors , pcm , and so many other things .
The X is fixed and am happy so if it's not fully fixed, I got a 6 months warranty on the job .
Mr.Mark the truck do it again today. They changed the harnesses and the connectors plus the sensors again , so am lost now .
I have a wrecked 2000 4x4 5.4l expedition that have a new 2k mile transmission before my brother in law flipped it . Can I swap that transmission In the excursion . I think both trans are 4r100 .
If your truck is a 4x4 and the Expedition trans is a 4R100 it will bolt up. The 4R100 from a 5.4L has less plates in some of the clutches so it may not last a long time.
I Drove the X for 483 miles today but nothing happened
