The only reason I went with the two different looms is that is all I had! I didn't have enough big stuff. Not too many people are gonna nitpick like you Travis! Most people will never see it.
Glad you got it running Glenn! Sounds good. Get that thing out for a test drive!
I can't wait Darin. Still have a lot to do. Mutifuntion switch, put my aux fuel tank in, 5th wheel rails mounted in bed, switch my brake controllers from mule to mare, u joints, get a tool box, put air bags on, and of course install my gauges!!
Originally Posted by ReBilld
Sounds good buddy! Glad you got it done! See, it didn't take you that long for the amount of work you did! Good job!
I'm just short of two and a half months Bill, if I did this for a living I would starve to death, LOL Thanks!
Originally Posted by strokin'_tatsch
Ok. I figured y'all mighta left them seperate like that in case you wanted to go back to OBS harnesses. Doesn't matter to me, was just wondering. LOL
No plans for that, I even did the 50 cent mod. I'm sure glad I noticed the wiring when the engine was running, it was rubbing on a pushrod. I didn't even know about this and I don't think the OBS uvch have this, IDK, but there are clips to snap in. Inbetween the first two injectors and last two injectors on the solid piece of black plastic that the wires run thru is a raised part the snaps into the gasket. Just saying incase someone else like me didn't know that, LOL
Mike, thanks again for posting that. Maybe I'll learn someday. When I was talking about some vibration, my nephew stopped in later and I told him to start it and see what he thought. As soon as he turned the key he said, "jake stands" duh, makes sense.
The OBS wiring can rub the pushrods and rockers also. Not as easy as the SD wiring though. The SD front and back injector/GP wires run a little more distance, so they can get close sometimes if you don't look at them.
that is very exciting for sure! good luck with the rest of finishing the odds and ends!
Thanks Aaron. Thanks Pete.
I should probably explain what I was telling Mike about vibration. When I called him to ask if he would post my video I told him I was a little concerned about vibration cranking it over and when it was running. When my nephew pointed out that it was the jake stands sending the vibration back up thru the frame, it made perfect sense. I'll see for sure when I get it on rubber. Another thing I was surprised at was no leaks except for one on a hole by the fuel filters. Tighten it up and that was it.
I got four codes off the scanner:
0603 KAM, to be expected without battery's in it for awhile.
0344 CMP sensor curcuit intermiten
1212 ICP voltage not at expected level.
0470 EBP sensor curcuit malfuntion
CONGRATULATIONS YOU DID IT I was thinking about this the other day, maybe you would enjoy updating
Originally Posted by oldbird1965
This stuff has been swirling around in my head and to put it into a list is shocking, a real reality check. I'm not going to get all this done, all I can say is OMG, what have I gotten myself into?? I'm sure I've forgotten a few things. I want to know who's bright idea was it to get a dually cc? LOL
1. John Woods trans-DONE
2. GP relay switch-DONE
3. Brakes-DONE
4. Front end alignment to be done Tuesday. DONE
5. Take off fuel bowl and install E fuel.
6. Send injectors to Jim for stage II's.
7. Remove DP & stock exhaust, install diamond eye 4" turbo back exhaust.
8. Send in HPOP to Joey for a T500.
9. Mod the fuel tank filler necks.
10. Replace multifuntion switch (no emergency flashers working)
11. Replace GP's
12. Replace UVCH's
13. Installl s366 turbo and IC mount kit.
14. Install IC
15. Install 6.0 trans cooler
16. Swap aluminum radiator out of the mule into the mare.
17. Swap starters
18. Swap alternators DONE
19. Swap batteries DONE
20. Swap GPR's DONE
21. Install new U joints & carrier bearing.
22. Trans filter
23. Coolant filter
24. 6637
25. CCV mod
26. New water pump
27. switch over water injection, don't connect it up LOL
28. switch over my aux fuel tank
29. switch over my 5th wheel hitch & tailgate.
30. switch over dual tensioner mod DONE
31. switch over the new coolant overflow tank
32. switch over the FS2500 oil bypass
33. switch over the my diy oil cooler
34. switch chips, Tony's into the mule and Beans into the mare. DONE
35. put new raditor hoses in
36. Install 5 gauges, fuel pressure, oil pressure, EGT, coolant temp, boost. Scan guage already switched over.
37. Switch Map sensors DONE 38. Switch mule's HVHF Swamps IDM over from mule to the mare DONE 39. Change out passenger seat belt, its torn.
40. Get a new toolbox.
12548361[/COLOR]]This stuff has been swirling around in my head and to put it into a list is shocking, a real reality check. I'm not going to get all this done, all I can say is OMG, what have I gotten myself into?? I'm sure I've forgotten a few things. I want to know who's bright idea was it to get a dually cc? LOL
3. Brakes-DONE
5. Take off fuel bowl and install E fuel. DONE
6. Send injectors to Jim for stage II's. DONE
7. Remove DP & stock exhaust, install diamond eye 4" turbo back exhaust. DONE
8. Send in HPOP to Joey for a T500. DONE
11. Replace GP's DONE
12. Replace UVCH's DONE
13. Installl s366 turbo and IC mount kit. DONE
14. Install IC DONE
15. Install 6.0 trans cooler DONE
16. Swap aluminum radiator out of the mule into the mare. DONE
17. Swap starters DONE
20. Swap GPR's DONE
22. Trans filter
23. Coolant filter DONE
24. 6637
25. CCV mod DONE
26. New water pump DONE
27. switch over water injection, don't connect it up LOL NOT GOING TO DO
31. switch over the new coolant overflow tank DONE
32. switch over the FS2500 oil bypass DONE
33. switch over the my diy oil cooler NOT GOING TO DO
35. put new raditor hoses in DONE
I can't edit the first post, the edit box is not there??
That cam sensor code is probably for extended cranking getting it running. The 1212, I'm not sure why that would show up. ICP sensor look ok?
ICP sensor looks good but I do have a spare if need be.
Originally Posted by fordpride
0344 is caused from all the cranking.
1212 can be caused by all the air in the system.
I figured it was from all the cranking.
Originally Posted by DIYMechanic
Sweet! That ting sounds good Glenn. I can't wait to hear how it drives. Towing with that beast is totally going to make all the work worth it.
I can't wait for a drive but will because of the intake pipe I'm waiting on from Jake. Seems like no matter how much you plan ahead there is always something but I still have lots to do. My nephew again said to take my time, Thanks again Nate, your explanation on the wiring the e fuel is what made sense to me. I got it wired right, I think. My nephew said if I wanted to test the inerita switch to just tap it with a hammer and it should trip. He said there is just a little ball bearing in there that trips it out and it doesn't have to be mounted directional in any way. Then he proceeded to tell me stories of the different locations they put that thing on cars and how they are all different. Stories of dash boards being taken apart and trucks being tore apart looking for that darn thing, LOL. I guess its not funny if you were looking for one. If mine ever trips out easy then I'll do what you mentioned about putting a light on the dash somewhere to warn you of that.
