Thermostat Question
Old Dec 1, 2012 | 06:54 AM
chucknmesa's Avatar
chucknmesa
Thermostat Question
I purchased my 06 Super Duty diesel pickup in Arizona, new. Moved to South Dakota and have had issues with the truck warming up. Even in summer, have to warm up for 5-8 minutes before driving it and in winter, even with the block heater plugged in, takes about 30 min of idling to be able to drive without truck acting like its missing. Is there a difference in thermostats used in vehicles purchased in different parts of the country? Im thinking my problem could be related to the termostat opening to soon, not allowing the coolant to heat up properly. Any ideas?
Old Dec 1, 2012 | 07:50 AM
Tom's Avatar
Tom
I think it's likely that something is wrong other than the thermostat. You should be able to start your truck up in 10° weather after sitting for weeks and drive down the road without it running badly. Sounds to me like you're having injector stiction, but I'm certainly not the expert.
I'm going to send this one down to the 6.0L Powerstroke forum.
Old Dec 1, 2012 | 09:07 AM
Curt's05's Avatar
Curt's05
Wiser by FTE
It could be your glow plugs not working. I had a open thermostat and my 04 ran fine in cold weather.
Old Dec 1, 2012 | 09:11 AM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Test the FICM also.
Old Dec 1, 2012 | 09:13 AM
69cj's Avatar
69cj
You also and first need to check the ficm voltage key on, key on cranking and key on running. Should never be below 47 volts. What type of oil and filters are you running. Only OEM filters for the fuel and oil. When cold try 5w40 oil. I run it year around. The truck likes it.
Old Dec 1, 2012 | 11:21 AM
dannyboy950's Avatar
dannyboy950
While thermostats are the same you may need to have your truck pcm recalibrated to the different environment it is living/working in. Thats a pretty big jump in both operateing temps and altitude depending on where in s.dakota.
Check with ford.
Old Dec 1, 2012 | 11:46 AM
daddykitty's Avatar
daddykitty
What kind of oil are you running? If you are from AZ like i am you would have been running 15-40. Did you change to a 5-40 for the colder weather?
Old Dec 1, 2012 | 02:25 PM
chucknmesa's Avatar
chucknmesa
I do use 5-40 oil.
Old Dec 1, 2012 | 02:41 PM
nonyabiztoo's Avatar
nonyabiztoo
I agree with Crazy 001, sounds like stiction to me.
Old Dec 1, 2012 | 02:44 PM
BLADE35's Avatar
BLADE35
You need a New thermostat to that Arizona Heat Weaked the Spring
And you have Other Issues Search the Site for a Gauge Setup
Old Dec 1, 2012 | 02:50 PM
BLADE35's Avatar
BLADE35
Start with Batterys Alternator and FICM
You have a Problem
I dont even Plug in and Can Take off in 10 minutes and Be OK No Miss at Like 32*f
It Not GP cause you dont Complain about the start
30 minutes and still have a Mis is a Problem
JeffMcMahon
Mar 4, 2018 09:05 PM
bgab3
Jan 5, 2013 08:17 PM
BigTires
Dec 2, 2010 07:03 AM
Dead Meat
47
Mar 11, 2010 11:24 PM
Kid 67y
1983 - 2012 Ranger & B-Series
Apr 4, 2007 05:05 PM
