thermostat question?
Old Dec 2, 2010 | 01:40 AM
BigTires's Avatar
BigTires
when i start my truck up when its cold out if i were to let it sit and idle until the heat was warm in there before i left it would have to sit like 30min. or more before i could leave. im pretty sure this is normal with a diesel. i was told the other day there truck 99 f-250 only takes like 5 min or so to warm up. i was told this is because i guess they changed out the thermostat guessing i temp one. guess it cost like 30 bucks more. so just wondering how true this was and if anyone else has done this. just looking for more info on this.
Old Dec 2, 2010 | 03:23 AM
Muktown's Avatar
Muktown
A thermostat wont change how fast it warms up just how warm it allows the engine to get once it reaches normal operating temp.just plug the block heater about 3 hrs before you leave in if you want instant heat. I have mine set up on a heavy duty timer set 3 hours before I go to work
Old Dec 2, 2010 | 07:03 AM
Ponyboychris's Avatar
Ponyboychris
A block heater will help a lot. Plus on the mornings that I forget to plug it in, I start it, let it idle for a few minutes then drive it easy. It will warm up faster under a load verses just idling.
