Sponsored by: Real Truck
Fuel injectors
Old Dec 1, 2012 | 06:46 AM
pcollins's Avatar
pcollins
Exclamation Fuel injectors
I drive a '07 SD 6.0 with 137,000. Bought it for pulling camper. Was in mountains and blew engine. Now it has a '05 engine with 100,000 miles. Camper was a 13,000 5th wheel. Not sure what happened, mechanic said either the computer went bad and fouled fuel injector #7 or something made injector stick open. End result $7000.00. Is there something I can do to watch engine like scan gauge or something. Like the truck and want to keep it, but now gunshy on driving it.
Old Dec 1, 2012 | 02:06 PM
nonyabiztoo's Avatar
nonyabiztoo
I'm not nearly the expert that some on this forum are, but here's my 2 cents.
As long as you keep the fluid levels up and do maintenance at least as scheduled, it should last a looong time. I had a 93 f250 ec 4X4 and put over 200k miles on it when it was stolen, then a 99 f250 ec 4X4 with close to 250 K on it when I got tired of pushing the clutch and upgraded to an 05 f250 crew 4X4 which now has 230k on it.
If your state allows it, I suggest the EGR delete and definitely the $50 blue spring fuel pressure update. The blue spring can be done by anyone that knows which end of a ratchet to hold in about an hour or less, EGR, a little longer, maybe half a day.
Old Dec 2, 2012 | 05:47 PM
pcollins's Avatar
pcollins
Thanks.
carrollti
Mar 20, 2012 01:55 PM
BenRoot
Feb 12, 2012 08:19 AM
ciscofreak
Sep 9, 2009 01:37 PM
SOB Racing
Jun 12, 2009 07:06 PM
beezf350
Dec 6, 2008 12:36 PM
