Injectors
Old Mar 19, 2012 | 07:57 PM
carrollti's Avatar
carrollti
Injectors
Need help!!!!!!!!!!!! I am in the process of replacing all (8) of my injectors. Problem started when I was hooked up to our camper and pulling up a slight incline I lost power. Going from 60 down to 15 within 1/2 mile. dealer replaced 1 injector and said that I was good to go. Not hooked up again with the same problem. What would cause the injectors to go?
Old Mar 19, 2012 | 08:25 PM
BLADE35's Avatar
BLADE35
A few things will KILL Injectors
1. Low Fuel Pressure
2. Not changing the Oil at correct interval
3. A bad FICM from Low Voltage
Most of us do the Blue spring mod to keep fuel press alittle higher. The injector is a side Load and Plunger Driven so the fuel is the Lube for the Plunger
To low Fuel Press will cause the plunger to Wear and hang up
Old Mar 20, 2012 | 01:29 PM
dhag911's Avatar
dhag911
Can you read fuel pressure from a scan gauge ii?
Old Mar 20, 2012 | 01:47 PM
npccpartsman's Avatar
npccpartsman
No as there isn't a fuel pressure sensor. You NEED to get a fuel pressure gauge for your truck along with an EGT gauge if you pull a lot. I really don't think you're having an injector problem. I think the OP has other issues.
Have you cleaned the EGR and possibly the turbo?
Old Mar 20, 2012 | 01:55 PM
dhag911's Avatar
dhag911
I'm out of town right now so haven't got to that yet I do have turbo farting haven't watched the vgt to see what its doing I did buy an extended warranty thru ford and was going to take out to them after I check the EGR valve
Jimmy Cash
Jul 12, 2016 07:42 PM
MarzRickey
Jun 29, 2014 10:48 PM
caiati
Feb 7, 2012 09:18 AM
mcmayronne
May 8, 2005 01:48 AM
jpkoke02
Modular V8 (4.6L, 5.4L)
Apr 9, 2005 09:03 PM
