You tell me...
#46
I took the center section back out for measuring the center bracket's location. The method shown in the instructions might work, but I didn't want to take any chances. I marked on each door jamb, just under the side flaps of the headliner, with masking tape, placed so that a straight piece of angle iron aligned with the marks crossed right under the braket. Then used an upright from a point marked on that up to the bracket. It worked perfectly, I hit it dead-on.
A piece of advice when drilling holes for the side flaps' screws... If your drill bit is more than 3/4" - 1" long, it's possible for the bit to put a nice little dimple in your roof, right above the drip rail, when it breaks thru... Use a drill-stop. PS -- not a one of the original 6 holes on each side aligned with the 3 in the headliner.
I made a posterboard template of the rear window pieces, then cut it in half. Put one end around the window, the other against the jamb, and slipped one over the other to determine the required length for a 51-52. The end result is you need to trim right at 7 inches from each side.
#48
So I was right about the 6 to 8 inches having to be cut out. My wife was wrong!
I will not tell her though. "yes you're right dear" is my standard answer to all everything she questions even if i know it is not correct. More harmonious that way.
But I am glad you got it all sorted out Ross. I used a broken drill bit that I had which was only about a 1/2" long seated in the drill chuck. However when I did the right side panel below the rear window I missed the brace and drilled through the back of the cab on one of the screws. Nothing to much to worry about for me but someone who has a completely painted truck needs to very careful with.
#49
Ross some time back you or Terry sent me the .pdf files and I have them on my web site. For anyone interested:
Bonus Built cab headliner
That's great Bob, you should have Mo add it to the stickies for useful threads.
Kevin, you are a wise man...
edit: Well I made one screw-up... when I cut the side piece, I didn't cut it so the lower side under the window was extended, thinking the separate piece would cover it. Nope. It's too short for a 51-52. I'll need to glue it...
#50
#51
Years ago while drilling a hole in a inner door panel I learned a valuable lesson about drill stops. When I punched through the door skin I ended up drilling a 1/4" hole approx halfway through the door glass of the Eldo I was working on......needless to say my boss wasn't impressed with the sharpness of my drill bits.
After that I found that a length of vacuum hose cut to length and slipped over the bit is a very handy thing and kept the boss happier as well.
Bobby
Bobby
#52
That's a tip worthy of going in the "Cool Tips & Tricks" thread! Fingers in front of the chuck work too, but....
#53
Bobby
Bobby
Bobby, BTW, are you sure the hole measured 1/4", I bet it was a lot bigger once you hit that tempered glass with the bit Kind of funny now, but not all that funny at the time, was it?
#54
LOL....
yea, that day I also learned to roll the windows up before drilling out any rivets, etc. I also learned a lot of colorful words from the service manager. It was a full day of learning.
The bit only went about half way through the glass. I'm sure if it would have penetrated all the way through it would have shattered the glass. You know, when you learn a lesson the hard way like that, its a lesson learned for life.
Bobby
Bobby
#55
#56
I see quite a few claims like that.
#57
Fat Fendered Ford
07-16-2003 02:50 PM
