PCM NOT RESPONDING
Old Nov 29, 2012 | 05:05 PM
bakerbuilttracks's Avatar
bakerbuilttracks
PCM NOT RESPONDING
Hey y'all, re-built my fuel bowl last week and when i took the heater out it basically fell apart. I was able to tie wire it back up fairly good as i didn't know if this was a critical part " New one on order". SO hoping to limp by i have had no issues. I remember in the rebuild instructions it stating that the FB heater is linked to the PCM fuse. If the FB heater shorts it will blow that fuse causing the truck not to start.
Ive ran it quite a bit with no trouble at all with the wired up heater in the bowl.
Haven't ran it since last fri, i have been at home with the FLU since sat morning. Feeling a lot better today i walk out to run to the store turn the key over waited till the dinger went off " my wifes picture is in the right corner where the wts light is" and she turned over strong but never fired up. Also my Edge Evo monitor said "PCM NOT RESPONDING "
Dose This sound like the PCM Fuse ? If so where is it located at?
If its blown i will replace it and should i un-plug the heater from the back of the bowl? If i do how long can i run with the thing unplugged? is it ok or not? i don't want to hurt anything.
Old Nov 29, 2012 | 05:10 PM
BigAlsPSD's Avatar
BigAlsPSD
Location would be dependent on year model, it's the fuse for the PCM relay, not really the PCM.
You will be fine to run it until you get your parts, or even if you choose not to replace it. Leaving it unplugged outside the fuel bowl though, does not give you a WIF, if it ever arises. That's why I suggest unplugging it inside the bowl and leaving the outer unplugged.
Edit: Fuse 30 or 19 IIRC.
Old Nov 29, 2012 | 05:27 PM
bakerbuilttracks
Its a late 99 built 6/99. So its the PCM Relay Fuse. Im just looking in my book and it has so many fuses with PCM in the Title.
Fuse 30 or 19 i will pull em and check.
I have never had the WIF light come on...... Ever so i will probably just unplug it from behind the bowl. My new one should be here next week.
Going to give it a shot after supper, Let ya know what i figure out
Old Nov 29, 2012 | 06:01 PM
howellt39's Avatar
howellt39
I lost the #30 fuse a couple years ago due to a worn wiring harness over the DS VC. If you unplug the fuel bowl heater and #30 pops again at Key-On, might check there and at the DS shock mount. Just giving you some ammo beforehand in case you need it and the fuel bowl heater isn't the culprit.
Old Nov 29, 2012 | 06:29 PM
bakerbuilttracks
Awesome advice, hope its just the heater causin it. If its the harness then with the time i been out sick bet the damn squirrels got in there. If so were gavin a squirrel killin round her.....
Old Nov 29, 2012 | 06:31 PM
bakerbuilttracks
Yep u nailed it. #30 fuse which is a 30A " INSIDE THE CAB" was BLOWED ! And my luck i don't have one. Headed to Wally now....... Post back with results
Old Nov 29, 2012 | 06:39 PM
BigAlsPSD's Avatar
BigAlsPSD
Good to hear, hopefully it was just the heater, leave it unplugged, it'll be fine, I've never had water in fuel either, until you replace it.
Old Nov 29, 2012 | 07:57 PM
bakerbuilttracks
Thanks for all the help Al , Just got home from Wally got a 5 pac of 30s and will be putting them in my electrical kit in my tool box. Im almost positive it was the heater in the bowl that caused it to blow. When i took it apart last week the small round looking things that are on the wire connecting it to the plate first fell off the plate then fell off the wire. I wire tied down the wire that has the connecter on it to the plate to limp by so I'm shure thats what caused it to blow.
I will install the fuse in the morning and see where we go. If i don't post back I'm back up and on the road. Thanks again Al and everyone for the awesome quick help !
Old Nov 29, 2012 | 09:09 PM
1fixitman's Avatar
1fixitman
If you drained your batteries a bit by trying to crank then you want to plug in the battery charger to top the batteries off.
glasseater
34
Dec 23, 2015 10:46 PM
Tow Zone
Nov 1, 2013 05:24 AM
sflem849
17
May 19, 2011 09:11 AM
RubberDuck
18
Nov 18, 2008 11:54 PM
mcjones44us
17
Sep 14, 2007 02:12 PM
