Sponsored by: Real Truck
4wd failure
Old Nov 29, 2012 | 04:53 PM
dante27's Avatar
dante27
4wd failure
When I switch my 2004 f350 SD 4X4 into 4wd high or 4wd low it doesn't make the switch. I checked the hubs and both are in auto. I tried them in lock position but still no 4wd. Any suggestions?
Old Nov 29, 2012 | 05:21 PM
boj760's Avatar
boj760
Does the 4WD light in the dash come on? Do you hear the transfer case make that oh so cool noise when it engages? If not there could be something wrong in there, or maybe a blown fuse to the transfer case motor/solenoid that engages the front driveshaft. I'm not a heavy like some here, but maybe a place to start.
What do the 60lb brains on the forum think?
Old Nov 29, 2012 | 05:41 PM
redford's Avatar
redford
FTE Leadership Emeritus
60 lb brains?
I read posts like this, I get warm fuzzy feelings for my manual hubs and case.
But, boj760 is on the right track. How do you know that you do not have 4 wheel drive? No dash lights telling you 4H or 4L is activated? No noise when you turn the switch?
Your problem seems to be centered on the transfer case shift motor. It is either inoperative or is not getting power.
Old Nov 29, 2012 | 05:50 PM
dante27's Avatar
dante27
No dash light no transfer case clunk no 4wd at all
Old Dec 8, 2012 | 05:17 AM
dante27's Avatar
dante27
I check all fuses and all ok, the dash switch doesn't seem to do anything. How can I troubleshoot the 4wd shift motor for power and operation?
HenryII
Dec 7, 2012 11:40 AM
travfrederick
Offroad & 4x4
Dec 21, 2008 11:35 PM
Trakk
Mar 8, 2008 12:30 PM
jzlvr1
1983 - 2012 Ranger & B-Series
Jan 1, 2008 04:10 PM
Plugman
Apr 19, 2007 08:02 PM
