Sponsored by: Auxito
Headers wont seal
Old Aug 13, 2008 | 01:01 PM
Guttshott's Avatar
Guttshott
Headers wont seal
I just put a new set of hedman headers on my '93 302...The drivers side will not stop leaking....I changed gaskets got double gaskets on it now and it wont stop...They are only regular gaskets...Please Help!!!...The noise is driving me crazy!!
Old Aug 15, 2008 | 10:27 AM
kingrat427's Avatar
kingrat427
if the surfaces are clean cleaner than clean, it does't take much on the surafce to create a leak. you could try to soak the gaskets in water for 3to 4 hrs that might work
i have used this trick on my chevelle and it worked . hope this helps good luck
kingrat427
Old Aug 15, 2008 | 10:34 AM
Bear River's Avatar
Bear River
Former ******
This is leaking against the head or at the collector? Are the headers perfectly flat, or is there a possibility they could be warped? Any defect can cause a leak. Also some types of gaskets are more prone to leak that others. I like metal gaskets with raised edges or rims. Graphite gaskets are good for some things, but they really like to leak, they don't compress well, and they don't adapt to surface variations very well. If they have metal rims, they are much better than just regular graphite gaskets.
As for the collector end is it a flat surface or does it use a donut? If it is flat, the above applies to it. Also if it is flat, where are the flex joints. If it is a donut, those tend to seal well if the flange is perfectly round and has no serious defects. They also provide all the stress relief the system needs.
Old Aug 15, 2008 | 11:01 AM
mwsF250's Avatar
mwsF250
My experience (fixed several sets of leaky headers installed by others) is that the leading cause is overtorquing the bolts and distorting the flange.
I personally like dead soft copper gaskets.
Try a new set of gaskets and follow torque specs EXACTLY. More is absolutely not better.
Also, make sure everything is loose so the header can float a bit so the flange can align perfectly flat to head. This includes the collector.
If they still leak, odds are the flange is warped. Remove and have it milled flat.
Old Aug 15, 2008 | 12:59 PM
xtrford's Avatar
xtrford
Try Fel-pro gaskets, good quality and are a little forgiving for small flaws in the header flange surfaces.
Your problem might be the headers themselves....are they used? What brand did you go with?
