So I was given on old ford d700 school bus with a 332 y block. I am scraping the bus, wondering if those 332's are boat anchors or if its worth dropping it out?
1 would think getting parts for it would be an issue. No **** Sherlock! All the parts are obsolete, very hard to find.
A member of FTE was looking for rod/main bearings, rings, seals and an overhaul gasket set for a 332.
Said he tried autoparts stores and when he mentioned the engine size, the parts clucks were either clueless or said it's an FE engine (332 FE available 1958/60).
I found all the obsolete parts at Green Sales and at a dealer in SC, member bought them.
