engine trouble 428
Old Nov 29, 2012 | 01:06 AM
High76boy's Avatar
High76boy
engine trouble 428
I have just bought a 76 f250 that has a 428 well just my luck had a rear main seal leaking well my luck continues the crank has play is this normal at all or do i need main bearing can i change them with the motor in the truck do i need to change rod bearing too or just the main bearing motor ran great just leaked oil like a civ.
Old Nov 29, 2012 | 01:23 AM
Ziegelsteinfaust's Avatar
Ziegelsteinfaust
Crank end play is normal, but it does have to be with in spec.
If your crank end play is to much I would do all the bearings to be safe. As the end bearing is the one that sets up end play, and it allows you to do the seal at the same time. Or vise versa depending on how you want to state it.
Old Nov 29, 2012 | 01:57 AM
High76boy's Avatar
High76boy
How much is play is normal is the any way to adjust it or is it just is what it is
Old Nov 29, 2012 | 07:42 AM
earthquake68's Avatar
earthquake68
No, you can't adjust it. You have to replace the thrust bearing. (the main bearing that has sides on it) Anyway, around .006" is about all you want in there. If it were me, I'd just bite the bullet and pull the engine. Take it to the machine shop and have them go through it. 428's (if that's what it really is) don't grow on trees anymore. There's no sense in trying to band aid something that could lead to a catastrophic failure later on. Spend a little now to freshen it up, or limp it along and shred what you have and be forced to look for another block. (I've seen it too many times)
Old Nov 29, 2012 | 08:06 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Chevy's thrust bearing is No 5, on Fords the center main (No. 3) is the thrust bearing.
Ford's spec on the crankshaft end play for the FE is .004"-.010" with a max limit of .014"
Old Nov 30, 2012 | 12:34 AM
High76boy's Avatar
High76boy
just an up date i do need to lower end rebuilt looks like main bearing are shot as well as 4 of the rod bearings glad i got it when i did or it could be another one at the scrap yard
Old Nov 30, 2012 | 12:53 AM
7636074460's Avatar
7636074460
bearings are expensive for FE blocks, i just did one. 73.99 just for the mains FYI. it may be worth it to you to buy a reman crank kit for 200? which comes with the correct bearings and all ready to go. Make sure but a 390 kit should work.
Old Nov 30, 2012 | 12:57 AM
High76boy's Avatar
High76boy
the crank is self looks really good and the rods and caps look good should i get it machined anyways or just put new bearings in the re assemble?
Old Nov 30, 2012 | 01:06 AM
85e150's Avatar
85e150
Have it mic'ed and polished at a minimum. Check the clearances. Why did the old bearings go bad? How was the compression? If there was an oiling issue, do you think the cam bearings escaped?
See post 4....
Old Nov 30, 2012 | 01:26 AM
High76boy's Avatar
High76boy
the rod bearing wasnt horrible no scoring just the the metal on the surface was rubbed down to what looked like copper havent got to the main bearing yet (tomorrows project) will post what i see
Old Nov 30, 2012 | 01:42 AM
High76boy's Avatar
High76boy
and just wondering im going to keep the 428 regaurd less but does anyone know the factory horse power or torque of it? Or is it a good motor for the truck? i know there in high demand of classic muscle cars, or should i look for a good 390 or 460
Old Nov 30, 2012 | 09:55 AM
85e150's Avatar
85e150
345/462 under the old SAE Gross HP rating--taken at the flywheel with no exhaust system, underhood air cleaner, accessories. Figure 20% less for SAE Net.
That is the standard rating. CJ's and PI's were higher, although CJ's were rated lower to fool the insurance man.
FE Series Engine Specification Chart
As for it being a good truck engine, if it runs good once you tidy up your bearing issue and figure out your oiling or other problems, if any, it should be fine. Compression is a bit high at 10.5:1. Does this like premium fuel?
Are you sure it's a 428? Check the markings on the crank and check the stoke. 3.98 is the magic number, so your crank arms should be almost 2".
Old Nov 30, 2012 | 10:11 AM
High76boy's Avatar
High76boy
How do you measure the crank arms a what markings am I lookin for on the crank?
Old Nov 30, 2012 | 10:24 AM
High76boy's Avatar
High76boy
and so far the most unique marking ive seen was a welded a upside down on the rear of the block i have never seen this before
Old Nov 30, 2012 | 02:50 PM
montana_highboy's Avatar
montana_highboy
The upside down "A" scratch mark is a standard 428 block.
Were it a "C" scratch mark it would denote a reinforced 428 block, used in the 428PI, 428CJ, and 428SCJ.
