Best head gasket ?
Old Nov 28, 2012 | 08:21 PM
19687.3idi's Avatar
19687.3idi
Best head gasket ?
Is there a better head gasket to use in my rebuild? I will be running about 20psi and just wanted to know if some are better than others
Old Nov 28, 2012 | 08:57 PM
1989f250IDI's Avatar
1989f250IDI
What turbo setup are you running
Old Nov 28, 2012 | 09:15 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
i used Fel-Pro recently when i did mine. no leaks yet(knock on wood!)lol.
the prep you do to the block surface and the head is far more important than the head gasket.
Old Nov 28, 2012 | 09:17 PM
hairyboxnoogle's Avatar
hairyboxnoogle
Fel pro or victor rienz are the two good ones. IIRC one is slightly better than the other, but the difference is very small. I would get whichever is easier / cheaper to come by. As long as you have studs you should be good. Are you planning on running a re-ground cam?
Old Nov 28, 2012 | 09:41 PM
19687.3idi's Avatar
19687.3idi
I am going to do a custom turbo setup with a hx35. And wanted the type4 cam but he has not responded to my message.
Old Nov 28, 2012 | 11:13 PM
RacinNdrummin's Avatar
RacinNdrummin
I have Felpros on mine, NMB2 has VR on his... Both are good gaskets and holding 350+ whp...
Old Nov 28, 2012 | 11:46 PM
hairyboxnoogle
Not to take anything away from russ but i would look at either racins or NMB2s cam for a turbo application. More low end / midrange, racin, mid-range top-end, nmb2. Just my .02
Old Nov 29, 2012 | 12:35 AM
RacinNdrummin
Mike, You are right on, but I would also tuck Russ' cam in there and say its good for an N/A truck or something with lower boost numbers...Not one cam is all around better than the other, but they are all better for their particular ranges...
Old Nov 30, 2012 | 09:05 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
depends on how you run the truck though.take a look at that dyno slip again with all the cams grafted together.Russ has the cam id be putting in mine,should i ever need to pull the engine for something.
Old Nov 30, 2012 | 10:42 PM
RacinNdrummin
You would be right judging on existing dyno slips... However, wait til my cam hits the dyno, we shall see what she does... And I am confident ...
Old Nov 30, 2012 | 10:50 PM
hairyboxnoogle
What dyno sheets are we talkin about here?
If you plan on doing more than the typical 10-15lbs i would strongly advise at least a stg 1 cam in order to help with excessive cylinder pressure.
Old Dec 1, 2012 | 12:35 AM
FORDF250HDXLT
this one.........
Originally Posted by 91dirtydiesel
this is the one where all the cams are in it (this was my first run, the big blue line is because i held the same rpm to long before i backed out and it kept sending data)
<a href="http://s1095.photobucket.com/albums/i463/91dirtydiesel/?action=view&amp;current=dynocams.jpg" target="_blank"><img src="http://i1095.photobucket.com/albums/i463/91dirtydiesel/dynocams.jpg" border="0" alt="Photobucket"></a>
but now that i see racins last reply,i see things might have changed.looking forward to it.
there you can see the cam in Russ's truck is the clear winner for a street/tow rig.the power is right where your engine runs most of it's time.
really,we know the idi does much better when talking anyway.where she could use a bit more hp is the lower rpms,so you won't need to make her talk so much when towing/uphill.least to me,for pure economy reasons alone is enough to see it wins.never mind having a more enjoyable crisp response right in normal dd activity.
Old Dec 1, 2012 | 03:33 PM
19687.3idi's Avatar
19687.3idi
Thanks for the better brands of head gaskets. Anouther question t3 or t4 turbo? I was thinking of the t3 for faster spooling. RacinNdrummin I sent you back a message but not sure if it went through.
Old Dec 1, 2012 | 07:11 PM
88 Ford IDI's Avatar
88 Ford IDI
It depends on how much boost you want. A t3 has a built in wastegate and a t4 doesn't. On the other hand, if you are welding your own setup any you can always use an external wastegate as well. IMO I would go with the t3 for better spool.
Old Dec 1, 2012 | 09:04 PM
RacinNdrummin
T3 framed turbos can supply all the air we need for these things, but they are getting at their limit on the upper end... You can run a T4 hot wheel in a T3 housing... Thats what my big turbo upgrade is... So basically you get a wastegated T4 turbo... Only drawback is the housing sizes are small and dont flow anywhere near the amount a T4 housing does...
