6.0 scan
Old Nov 28, 2012 | 06:24 PM
rusbukt's Avatar
rusbukt
6.0 scan
Here is what came up on my 05 at a local Diesel Performance shop after check engine came on.
P0261,P0264,P0267,P0270,P0273,P0276,P0279,P0282. 1-8 Injector Ckt Low.
P0528 Fan Speed Sensor Ckt No Signal
P0611 FICM Performance
Vehicle has slow cranking issue. Charging system O.K.
Appears one battery ( both are one year old) is not fully charging.
Could a faulty batt. (low voltage) cause any or all of these errors? I will be replacing batteries tomorrow.
Was quoted 950.00 to replace FICM. Sound reasonable?
Old Nov 28, 2012 | 06:33 PM
69cj's Avatar
69cj
Sounds like a low voltage condition may have taken out your ficm. Replace the batteries and then check your ficm voltage at key on, cranking and running. If below 45 volts at any time your ficm is done for. The tech folder has the proper testing procedure.
Old Nov 28, 2012 | 06:41 PM
rusbukt's Avatar
rusbukt
Thanks for the tip.
Old Nov 28, 2012 | 06:49 PM
dannyboy950's Avatar
dannyboy950
Also the FICM can be repaired by places like ficm repair.com for a lot less. a google search will find more. Low voltage will kill a ficm and cause injector problems because the bad ficm will not provide the proper voltages to the injectors which can in turn kill injectors. The cascade effect, or snowball if you prefer.
Old Nov 28, 2012 | 07:14 PM
Yahiko's Avatar
Yahiko
No.
Call Ed at FICM Repair.com - Your Source for FICM Repair
He will have the better option and he also has an
exchange program that you can ask about.
Sean
Old Nov 28, 2012 | 08:46 PM
cheezit's Avatar
cheezit
ficm and a fan cluth
stxbrowneyes
Dec 11, 2020 01:19 AM
Raw5768
Mar 22, 2017 09:50 AM
Flaman
Feb 26, 2017 05:48 PM
samsdad02
May 24, 2014 06:35 AM
king36
Aug 22, 2012 10:06 AM
