Got the truck month ago. Oasis only has four issues with tail lights and small stuff .my engine light has come on code po401.egr took out and cleaned but don't have programer to clear it yet.I took the egr out and cleaned it wasn't too dirty and put back in. Any advice. The inside of cooler had a little bit of old oil on bottom maybe 16 the of an inch
One thing that will really save you time,money and maybe even an engine ScanGaugeII : Linear Logic - Home of the ScanGauge
You can pick it up at Autozone for about $160.00. Spend a little time
wit hit and program in the Xguages and it is a very useful tool for your truck
to let you know what it's doing. That can save you a lot of time and $$.
It will also reset most of the engine codes with out pulling the batteries.
The other nice thing is it gives you most of the gauges that you will
be asked for when you are trying to fix a problem like this one. The only
2 big things it does not cover is Fuel pressure and EGT.
Ford did not think to include them in the PCM's list of sensors
Sean
