proportioning valve update...(not good)
Old Nov 28, 2012 | 07:11 AM
alchemist1's Avatar
alchemist1
Well, I have all of the EPDM o-rings coming from RF Carlson, so that's good. Problem is, when I look down the bore of the metering valve section (the one in front), I see a LOT of pitting and rust in the bore. I cleaned it out very well with a bottle brush on the end of a drill, but that brush won't touch the pitting. Afraid even if I get things back together, it won't work correctly.
anyone else see this pitting on their valve?
Old Nov 28, 2012 | 12:25 PM
mark a.'s Avatar
mark a.
They aren't really worth messing with for $59.95 you can have a new one. Ebay PROPORTIONING / COMBINATION BRAKE VALVE, 1976-1986 Ford F150,F250,F350 + Bronco | eBay I just bought one of these a while back for my truck and it works fine.
Old Nov 28, 2012 | 12:29 PM
fmc400's Avatar
fmc400
MSEE
Mark, did you have to modify your existing brake lines or change fittings?
Old Nov 28, 2012 | 01:08 PM
mark a.'s Avatar
mark a.
Nope, it went right in.
Old Nov 28, 2012 | 02:58 PM
hickory1991's Avatar
hickory1991
Lightbulb
How about switch. Does old harness work. Is the bleeding pin for front to rear covered with that black boot? Thanks Terry
Mikulh
19
Aug 3, 2016 04:52 PM
llcvt15
Sep 22, 2010 04:37 PM
steelerfantomo
Bronco II
Jan 27, 2005 10:01 AM
