alt lite
Old Nov 16, 2012 | 03:21 PM
docholy45's Avatar
docholy45
alt lite
i have a 1977 camper special replaced alt and volt reg gettin14.7on meter but alt lite stays on any ideas help
Old Nov 16, 2012 | 03:49 PM
fmc400's Avatar
fmc400
MSEE
Check these two things:
1) Make sure the ALT light goes OFF if you unplug the regulator. The regulator should be the ALT light's only path to ground.
2) Make sure you have a solid connection between the STA or S post of the alternator and the S terminal of the regulator. The regulator needs this signal to shut off the ALT light.
Report your results.
Old Nov 28, 2012 | 12:09 PM
docholy45's Avatar
docholy45
alt lite
checked everything as told lite still on
Old Nov 28, 2012 | 12:15 PM
fmc400's Avatar
fmc400
MSEE
I don't understand. The first instruction was to make sure the ALT light goes from ON to OFF if you unplug the regulator. You are saying the light is "still on;" I'm not sure to what that applies. What were your exact results of the first experiement?
Old Nov 28, 2012 | 02:36 PM
docholy45's Avatar
docholy45
alt lite goes out with volt reg unplugged have a goodconnection between s post on alt and reg lite is still on meter shows charge at13.88
Old Nov 28, 2012 | 05:28 PM
fmc400's Avatar
fmc400
MSEE
Thank you for the clarification. The only explanation for this is a faulty voltage regulator.
Damifiknow
Aug 14, 2015 03:50 PM
valley1221
Apr 25, 2013 09:21 PM
Schuyles
May 27, 2011 05:28 PM
Larry85355
Nov 13, 2008 04:28 PM
ken's 80
Electrical Systems/Wiring
Sep 2, 2008 05:51 PM
