can bus signal
Old Nov 27, 2012 | 04:14 PM
mrwrench's Avatar
mrwrench
can bus signal
I have a 2005 f250 diesel reg and 4x4 - I upgrade the factory am/fm radio to a 6dc mp3 Ford unit . Everithing work except the button lights.
Somebody know if my truck have Can Bus ?
where can I get can bus low and high signal ?
Old Nov 27, 2012 | 08:17 PM
dannyboy950's Avatar
dannyboy950
Can is a network data protocol voltage is 2v or less. The 05 does have can but limited functionality. CAN is for data transfer only it is not meant to supply power to anything.
Old Nov 27, 2012 | 11:01 PM
Yahiko's Avatar
Yahiko
Did you look at the plug pin out so that you got the signal
from the lamp dimmer? What year of head unit did you go to?
You may have to get an adaptor.
IF the 05 has not changed and it is the same as the 06
then you have on pin #3 LB/RD wire that is the instrument illumination feed
I wished I could give you more.
Sean
Old Nov 28, 2012 | 03:10 PM
mrwrench's Avatar
mrwrench
yes , the pin 3 is present ,
the new radio is 06/07 .
I plugged it in a 2007 Fusion ad the lights work when I plugged the 16 pin connector - (can bus)
My truck doesn't have the 16 pin harness .
SEAL1
All Things Towing
Jun 24, 2015 09:59 AM
swope1221
Aug 25, 2013 10:11 AM
KR-SD
Jul 24, 2012 12:53 PM
mrsdbro
Aug 16, 2009 06:25 PM
Carolina Tobacco
Oct 31, 2007 05:40 PM
