Understanding SCA
Old Nov 26, 2012 | 07:55 PM
nomad221's Avatar
nomad221
Understanding SCA
Hey guys, I need some help.
After my rad developed some pin hole leaks I decided to check the SCA level. I haven't checked it since I flushed and replaced with Fleetguard coolant about 20K ago.
Tested it tonight and found the coolant is at .6 SCA units per gal.. Not good.
I have one pint of Fleetguard DCA4 at my disposal and it says it will add 5 units per pint.
My question is, will it add 5 units to the whole system or ?
Thanks in advance.
Old Nov 26, 2012 | 10:30 PM
oldbird1965's Avatar
oldbird1965
If I recall correctly, two pints makes the whole system good. But, maybe someone else should back me up on that. Lately, I just use the pre mixed stuff.
Old Nov 26, 2012 | 10:32 PM
mongo12's Avatar
mongo12
two to three pints seems to be the norm.
Old Feb 4, 2013 | 03:35 PM
dougbrown's Avatar
dougbrown
Can u over fill the sca in our system. I have never checked it but doing a rad and coolent flush. Then adding a coolent filter with 12 units of sac. Is that to much? Have one with 6. I plan to run it 10,000 mile then change it. Also what do u guys run for anti freeze? Money tight so please keep that in mind.
Old Feb 4, 2013 | 09:08 PM
oldbird1965
I use this but I have never figured out the pre-charge filters. This antifreeze comes pre charged and I also don't know if you can over do it.
Conventional Antifreeze in Heavy
Old Feb 4, 2013 | 09:36 PM
fordpride's Avatar
fordpride
I ran the time release filter.
This may help you
http://www.donaldson.com/en/engine/s...ary/000376.pdf
ed foster
Apr 30, 2007 10:47 PM
F-250 PSD
Apr 1, 2005 10:48 PM
HDMustF250
Jan 22, 2004 07:30 PM
jakedog
Apr 22, 2002 08:39 PM
