Antifreeze?
Old Jan 5, 2013 | 04:59 AM
Major Marvin's Avatar
Major Marvin
Antifreeze?
Thinking about changing out the antifreeze since I've had the rig for some time now. When I first got the truck in Oct 2010 I had the coolant flushed out and replenished with one of those units found at an oil change place.
So here I am at 185,000 miles and want to change the thermostat to the 203 F version and use the best coolant for my truck. What's the best pre charged green coolant out there? I may be getting into extremely low temps.
Thanks
Old Jan 5, 2013 | 08:59 AM
Red97350's Avatar
Red97350
I used fleet charge, but it's pink instead of green. Precharged with sca's. I would do a coolant filter while you're at it.
Red
Old Jan 5, 2013 | 09:05 AM
baker1983's Avatar
baker1983
X2 fleet charge w a filter
Old Jan 5, 2013 | 07:19 PM
Major Marvin
Thanks for the replies, I appreciate the help
Old Jan 5, 2013 | 08:15 PM
fordpride's Avatar
fordpride
X3 Fleet charge
Old Jan 5, 2013 | 08:17 PM
Major Marvin
The Fleet Charge it shall be!
Old Jan 5, 2013 | 08:18 PM
fordpride's Avatar
fordpride
Tractor supply has the best price on it
Old Jan 5, 2013 | 08:23 PM
Major Marvin
Ok, one silly question. I may be moving to Alaska and want the best low temp rating I can get with this stuff. From the research I did it was 60% antifreeze to 40% distilled water. I heard our cooling system holds 4 gallons but I then heard someone else say 22 quarts. The bottom line is, how much of this stuff do I need to order to do the job right?
Old Jan 5, 2013 | 08:29 PM
fordpride's Avatar
fordpride
4gl of coolant and 4gl of destilled water.
Old Jan 5, 2013 | 08:36 PM
Major Marvin
So that would be 50-50. 60-40 is the max right?
Old Jan 5, 2013 | 08:41 PM
Major Marvin
I come up with 4.8 gallons of antifreeze to the rest being distilled water. Guess I can pour off 5 gallons of antifreeze and 3 of distilled water. Is that slightly overkill or will it make some sort of difference with .2 gallons extra antifreeze?
Old Jan 5, 2013 | 09:50 PM
madpogue's Avatar
madpogue
5+3 would mean 62.5% mix, close enough to 60. You can actually get FleetCharge at some Advance Auto stores. Order online for in-store pickup, look up the seemingly perpetual 20% discount, no shipping charge, comes to about $12 a gallon, which is way cheap for FleetCharge. And +1000 on DISTILLED water ONLY in any cooling system.
Old Jan 5, 2013 | 09:53 PM
Major Marvin
good deal, now I'll need the thermo, and neck? Will get the parts together and have a primo setup
Old Jan 6, 2013 | 07:35 AM
Red97350's Avatar
Red97350
Don't forget about the filter.
Red
Old Jan 6, 2013 | 09:17 PM
Major Marvin
Red
Looks fairly simple to install
