1993 7.3 idi starting problems
Old Nov 26, 2012 | 06:36 PM
CoalRoller7.3's Avatar
CoalRoller7.3
i have a 93 7.3 idi that i just put another used injector pump on. i have bled the lines, checked to see if fuel is coming out of the lines but still it will not start. i have tried starter fluid a couple times (which i know too much of will lock the motor up), and it will start for a spit second or a second and imediatly die. i have put new glow plugs, and a new glow plug relay. also, i have heard from several people that the injector pump DOES NOT need to be timed. is this true? PLEASE HELP!
Old Nov 26, 2012 | 09:22 PM
Ford_Six's Avatar
Ford_Six
Are you getting any smoke out the tailpipe while cranking? It does need to be timed btw-
Old Nov 26, 2012 | 09:57 PM
CoalRoller7.3
I don't see any coming out of the tail pipe. But it does slowly creep out of the top of the motor at the intake manifold (I took the air filter off) when it does crank up for that spit second... it pours white smoke. And how do you time the ip pump?
Old Nov 27, 2012 | 08:40 AM
farmert's Avatar
farmert
First off, how did you replace the IP? Hopefull you did not remove the timing gear cover. To me it sound like the timing is way off.
Old Nov 27, 2012 | 11:52 AM
Phy's Avatar
Phy
You know not to use starting fluid without disabling the glow plugs, right? Starting fluid with hot glow plugs often results in blown head gaskets, perforated pistons, and bent rods.
Assuming you didn't take off the gear cover & move the gear, then you should find a timing marks on the pump and the gear cover where they meet. With the engine off, move the pump to align the marks. This should be close enough to get it started.
If you did remove the gear, read this:
https://www.ford-trucks.com/forums/1...alignment.html
Old Nov 27, 2012 | 12:34 PM
joshofalltrades's Avatar
joshofalltrades
timing is similar to how it is in a gasser: it'll run if its close enough, but really ought to be set properly. whoever told you otherwise was wrong
Imleadguitar
Apr 3, 2017 11:44 AM
Wcpaz
Apr 22, 2007 02:11 PM
jdr0273
35
Nov 27, 2006 01:47 PM
jdr0273
Nov 5, 2006 12:48 PM
7.3 School Bus
May 2, 2006 07:39 PM
