Problems Starting
Old Apr 22, 2007 | 07:57 AM
Wcpaz's Avatar
Wcpaz
Problems Starting
I have a 2002 Ex w/7.3 the problem is that in the morning it act as if has no fuel once I have primed it,It will start same thing if the truck sit for an hour or so. I have looked to see if there are any fuel leaks around the lines but I can`t seem to find any. Just looking for some suggestions.
2002 Excursion 7.3L 4x4 6in Procomp lift 315/75-R16
Old Apr 22, 2007 | 08:54 AM
fatswany's Avatar
fatswany
Not familiar with how you "prime" a 7.3, but have you tried jumping out the glow plug relay, before you prime? When it does start, do you have a puff of white smoke? Had problems starting mine last year, with advice from the forum, diagnosed a bad GPR, replaced it, been great since.
Old Apr 22, 2007 | 12:18 PM
Wcpaz's Avatar
Wcpaz
Prime would be to spray starter fluid into the throttle body.No puff of smoke when it starts.
Old Apr 22, 2007 | 02:11 PM
Wcpaz's Avatar
Wcpaz
how do I determine if the GPR is bad
