Bad ball joints?
Old Nov 26, 2012 | 05:33 PM
TheBoneSentYea's Avatar
TheBoneSentYea
Bad ball joints?
I just took my 2000 7.3 to a ford dealership cause when i turned left or right there would be a terrible whine sound like the power steering pump was on its way out. Just got a phone call a few minutes ago and they told me my ball joints where causing the noise and was going to cost $919.00 to fix the upper and lower. Does this sound right?
correction: up and lower both passenger/driver side will cost $919.00
Old Nov 26, 2012 | 06:28 PM
tappit01's Avatar
tappit01
that sounds awfull high to me, you can buy them for under 150 . maybe just a local auto shop would be a much better deal. also, when mine went out it was a clunking sound not a whine
Old Nov 26, 2012 | 06:47 PM
Kdr358's Avatar
Kdr358
Are they crazy?! Find a local shop to do the work, You can get both sides done with new seals for that!
Old Nov 26, 2012 | 07:11 PM
hammer65's Avatar
hammer65
When I had a whine in my steering, I flushed the steerng system, and cleared it up.
I probably had gotten some water in the reservoir when I washed my engine.
I also replaced my ball joints myself, first time ever, and it wasn't such a hard job. And I am an old F**t.
I did have access to a hydraulic press, though.
You can do it yourself, and someone has the instructions on here for an EX.
Have a look at this. https://www.ford-trucks.com/forums/3...ll-joints.html
Old Nov 27, 2012 | 01:07 PM
lartross's Avatar
lartross
I did my own, plus new seals, rotors, pads, brake lines, hutch/harpoon, chip, 4" exhaust and guages for less than that...
Old Nov 27, 2012 | 04:06 PM
Brother Les's Avatar
Brother Les
Did you check the level of the power steering fluid before you took it to the stealer? I have been told that the fluid is not 'power steering fluid', but transmission fluid is what you need to use. A power steering 'flush' is a good start to do at home.
I have never heard of 'ball joints' making a whining noise..... 'clucking' noise, yes, but not whining.
Get your truck out of there asap before they 'find'more stuff 'wrong' with your truck than a low power steering reservoir. Say NO to ball joints until you come back and talk to your brothers here.....
Old Nov 27, 2012 | 04:09 PM
Firefighter 1406's Avatar
Firefighter 1406
Not that bad of a job. You could do it yourself with new seals and everything for $250-$350. Rent the tool from autozone and you will be money ahead. Just did mine a couple of weeks ago.
Old Nov 27, 2012 | 05:23 PM
F250_'s Avatar
F250_
You may have bad ball joints, but they will not cause the kind of whining noise you've described.
As for local shop costs, I had my local tire shop (excellent workmanship, responsible, and not gougers) do the passenger side with an alignment for me three years ago, and it ran about $475 ($69 for the alignment). With that in mind, the $919 isn't too far off the mark. HOWEVER, at that point in time I had never done ball joints myself and was cornered into a time demand which did not allow me to take my first shot at it. A month later, when I got my front leveling kit, I did the other side myself using a ball joint press from Advance Auto and an impact wrench... not too hard... took me about 4 hours for the driver side. Now, I've done about 5 sets of them and when I take my time, I can get both sides done in about 3 hours, and that includes the time to jack up the truck, do all the work, and clean up & put away all the tools afterwards. The cost difference is HUGE, and you KNOW that it was done right when you do it yourself (assuming you can follow directions)!!
Old Nov 27, 2012 | 07:58 PM
maximusfd's Avatar
maximusfd
Not trying to highjack the tread. All four of my ball joints are bad, so i was told. Also both seals for the auto 4x4 are bad. Had my tire shop tell me they would replace all and align for $1066. Found a man I trust tell me he would do all except align for $800.00. Is this to high? I do not have time to do the work myself right now.
Old Nov 27, 2012 | 10:52 PM
takotruckin's Avatar
takotruckin
I have heard the ball joints make a screeching noise when the steering wheel is turned before.
That is a pretty standard price to have them done. The R&R books about 5 hours @90-100/hr, alignment figure $100, list is probably close to $300 on the parts, plus tax if applicable.
bigtexan99
Sep 28, 2010 05:46 PM
SBastow
47
Oct 6, 2009 11:19 PM
shurbs2004
Oct 29, 2008 11:01 AM
bowdog
1997 - 2003 F150
Oct 17, 2008 10:20 PM
H1449-6
Feb 27, 2008 10:45 PM
