Fuel Leaking
Old Mar 12, 2015 | 03:55 PM
79F150400M's Avatar
79F150400M
Fuel Leaking
Put a Holley fuel pressure regulator on cuz the Edelbrock carb doesn't like the high pressure from the fuel pump. Cant seem to get it to stop leaking .I'm afraid if I tighten the fittings anymore i'll break something. Instructions say torque them to 40ft/lbs. Any ideas? (All new parts and fuel lines). Bout ready to use some pipe tape but I have a suspicion i shouldn't do that.
Old Mar 12, 2015 | 04:19 PM
AK FORD GUY's Avatar
AK FORD GUY
Is it all pipe fittings or is it fittings that gave a ferrule / or taper of some kind?
Which connection(s) are leaking?
Old Mar 13, 2015 | 11:21 AM
79F150400M's Avatar
79F150400M
I used some 3/8 brass connections, not barbed or tapered. Inlet is at the bottom and the outlets are on each side of the "T". Got one side plugged, the other side going to the carb is leaking or at least best I could tell. Couldn't leave it running too long to really see since I wasn't trying to light my truck on fire. Maybe the worm clamps i used suck...... I'll get some better ones and try that.
Old Mar 13, 2015 | 01:16 PM
AK FORD GUY
If the threads are pipe thread, a sealing compound is in order. Permatex makes a few good ones.
Fuel injection rated clamps seem to be the new thing, there are no serrations in them to cut up the hose when they are tightened.
A sealing compound on the threads should get you fixed up.
If you can, post up a couple pictures of the leaky connections. Also, one that shows the fittings while they are apart.
Old Mar 17, 2015 | 02:21 PM
79F150400M's Avatar
79F150400M
Thanks for the idea. Stopped at my local O'Reilly's and bought some Permatex thread sealer. I'll post back with the results.
Connecticut Calvin
Mar 30, 2018 05:27 PM
Randy777
Mar 4, 2015 07:12 PM
airwick51
Jun 6, 2013 09:28 AM
51merc
Sep 24, 2007 11:06 AM
freak98
Feb 19, 2005 06:56 AM
