2005 F-150 coolant change
Old 11-25-2012, 09:29 PM
Coondawg's Avatar
Coondawg
Coondawg is offline
Hey fellas. I was going to start getting the stuff together to do a coolant change and noticed that the coolant is a yellow color and none of the parts houses have that particular coolant. They said the universal 50/50 blend is fine but the owners manual says to use the yellow stuff.
Is there an aftermarket coolant I can use that will replace the factory stuff without any issues?
Also, how many gallons will I need?
Old 12-08-2012, 07:28 PM
Coondawg's Avatar
Coondawg
Coondawg is offline
I went with the Prestone 50/50 universal coolant. All the parts houses and mechanics I spoke with recommended it.
To do a thermostat change I used 1.5 gallons.
Old 12-09-2012, 07:16 AM
60DRB's Avatar
60DRB
60DRB is offline
Quick search shows this info;
How-To Matthew: Types of Coolant and Antifreeze
http://www.recycool.net/index.php?op...acts&Itemid=10
I guess the fine print on the jugs does matter... Although the Prestone site does say their product is compatable with any fluid type.
Old 12-09-2012, 09:31 AM
Coondawg's Avatar
Coondawg
Coondawg is offline
Thanks for the links.
Resendiz
41
10-21-2016 12:46 AM
Benchwrench
09-07-2010 01:33 PM
stumpy63
11-29-2008 12:44 PM
BigNiner19
2004 - 2008 F150
09-01-2008 10:47 PM
Lushman
04-08-2006 10:17 AM
Quick Reply: 2005 F-150 coolant change
