Brake line help
Old Nov 25, 2012 | 03:10 PM
super66's Avatar
super66
Brake line help
The brake lines on my '66 are, of course, shot. I'll be replacing them in their entirety. I'm swapping over to power brakes at the same time. My question is can I order pre-bent lines for a '67, which has a dual chamber MC, and make them work without reinventing the wheel?
Old Nov 25, 2012 | 07:53 PM
garbz2's Avatar
garbz2
Yes,
Just make sure the lines you order match the year of the master. Some are left exit and some are right exit. You will also need the matching safety valve.
Garbz
Old Nov 25, 2012 | 08:06 PM
super66's Avatar
super66
I did not think of that. Thanks.
Old Nov 25, 2012 | 08:16 PM
daveengelson's Avatar
daveengelson
Not sure bout 67 but they do make pre bent lines in either flex or rigid for 61-66? Replaced the brake line several yrs. ago on the 65 when I swapped to the p/s upgrade. Found the the local auto part stores carry the brake lines in either ridit or flexible lines that come in a roll and the ridig come in various lengths. I went with the ridid and then it was a matter of bending, cutting to desired length, and flaring. Regardless of which, suggest pass the line thru a piece of hose whereever the line passes thru an opening, bracket, etc. to prevent damage due to vibration.
Old Nov 25, 2012 | 08:32 PM
Shadowrider123's Avatar
Shadowrider123
I would give inline tube a call and thell them what you are doing. They should be able to hook you up with exactly what you need.
Old Nov 25, 2012 | 09:17 PM
super66's Avatar
super66
I'll give them a call. I'm further complicating this by converting the rear drums to discs. I'm using NPD's booster /master cylinder and a combo valve tuned for 4 wheel discs. I'll have to make a slight modification to the rear brake lines to accommodate the hoses to the calipers. I know that 4 wheel discs overkill on these trucks. It's just a matter of preference.
Old Nov 25, 2012 | 11:10 PM
Shadowrider123
Im doing the same.
I am using a 78 LTD rear end and redrilling the front rotors to 5x5.
That way I can use the LTDs m/c and porporting block.
Old Nov 26, 2012 | 04:51 AM
super66's Avatar
super66
I'm using the backing plates and caliper brackets from an Explorer.
Old Nov 26, 2012 | 09:05 AM
Shadowrider123
What rotors are you using?
Old Nov 26, 2012 | 11:06 AM
super66's Avatar
super66
The rotor comes from Currie Enterprises. They are approximately $75 each.
Old Nov 26, 2012 | 12:20 PM
Shadowrider123
I had not considered Currie.
For the price and ease of installiation, I would go with a kit on my 66 if they offer one.
I thought our 9in axles had the small bearing, but I looked at mine and it sure looks like the large bearing to me.
Old Nov 26, 2012 | 04:23 PM
super66's Avatar
super66
They do. The whole shooting match is around $530. $580 for cross drilled rotors The pics on their website show everything. It all looks like new stuff to me. It includes all necessary spacers and longer flange bolts. The best part is, it's all Ford parts.
It's the cheapest complete rear disc conversion I've found thus far.
Old Nov 26, 2012 | 07:21 PM
Shadowrider123
Im not seeing the kit on their website for our axles. The only Explorer kits I see are for the late Torino style large bearing axles.
I think that the offest on our backing plates is wrong for that kit.
There is a ebay seller buyautoparts that sells a kit for our trucks for $530, but it uses GM parts.
Jackford
Jul 14, 2022 06:09 AM
Amphihauler
Nov 14, 2017 06:42 AM
cbfomoco
Feb 6, 2007 09:48 PM
FLJ
Feb 18, 2006 05:42 PM
Charlie's Truck
Mar 9, 2003 08:25 PM
