Starting Issues
Old Nov 28, 2012 | 05:46 AM
Tugly's Avatar
Tugly
Thje last link in my signature might help.
This is sounding like IPR or HPOP issues. As you are facing the truck from the front, there is a solenoid to the right of the fuel bowl... way down under the rat nest of wires and hoses. You will see what looks like a flimsy nut on a bolt that holds a device with an electrical connector (solenoid coil). That is the IPR that controls your Injector Control Pressure (throttle) and the nut needs to be snug, but not overly tight... remember I mentioned "flimsy".
rayjamesfun
May 14, 2013 11:24 PM
the winemaker
Oct 18, 2010 07:24 PM
mxracer3276
16
Mar 5, 2009 08:35 PM
phillips91
May 2, 2008 02:46 PM
