Brake lights not working
Old Jul 17, 2018 | 09:59 PM
mattific's Avatar
mattific
Trying to fix the brake lights on a 2005 expedition my family has (think EB edition if that makes a difference) . All lights work except for brake lights (including 3rd brake light). Fuses are good, and tested the brake switch with a test light and that seems to be working fine (const power in, power out when pedal is pressed). Used the test light to see if any current was getting to the rear lights but nothing, not even on the factory trailer wiring. Short of tearing the dash apart to trace the wires, anyone have any suggestions? Electrical isn't really my thing so I figured I'd ask and searching didn't seem to give me an answer that applied to this case.
Old Jul 19, 2018 | 06:33 AM
projectSHO89's Avatar
projectSHO89
Which colored wires were you checking? There are two parallel sets of contacts in the stop lamp switch, on set is for the actual exterior stop lamps (LG/RD in, LG out supplied by fuse F2 in the CJB) while the other (RD/WH in, RD/LG out) is for logical signalling of the status of the pedal. Focus on the first circuit. I've come across multiple issues where the wire breaks inside the insulation near the switch.
BTclassics
1983 - 2012 Ranger & B-Series
Mar 14, 2017 01:19 AM
toastinloaf
Sep 27, 2011 09:16 PM
Lukes66
Feb 9, 2011 05:38 AM
declanok
Jan 12, 2004 03:03 PM
dave berry
1997 - 2003 F150
Apr 22, 2003 04:46 PM
