Popping Noise
Old Nov 23, 2012 | 08:49 AM
rickdavis81's Avatar
rickdavis81
Popping Noise
2000 Excursion V10 4x4. I'm getting a popping noise coming from the rear end when I apply the brakes and come to a complete stop and when I release the brakes to take off. It only happens the moment it comes to a complete stop and the moment it takes off. Not when I'm putting it in forward or reverse or accelerating or decelerating. U joints are fine. I was laying under the truck poking around the other day and when I roll it back and forth in park the few inches it'll go, when it comes to the end of it's travel the axle wraps a little and it seems like the transfer case output shaft flange is moving in and out of the transfercase and causing the noise. I'm assuming there is a snap ring holding the output bearing in place. I didn't have time to drop the driveshaft but am planning on it this weekend to see if it still does it when I roll it and to inspect the transfercase. I need to check to make sure the driveshaft splines are not siezed up but they seem to have a little freeplay to them. Anyone else have this problem? THanks
Old Nov 23, 2012 | 01:42 PM
EXv10's Avatar
EXv10
Take the slip joint apart, clean all the splines, and grease it.
Old Nov 23, 2012 | 02:41 PM
rickdavis81
Will do. Thanks
bshort09
Apr 29, 2015 07:18 PM
dlow11200
Modular V10 (6.8l)
Jan 16, 2011 01:59 PM
johnczub
Feb 15, 2007 03:17 PM
995.4SD
Feb 11, 2007 11:35 AM
omni
Sep 10, 2004 06:12 PM
