Battery light
Old Nov 22, 2012 | 04:49 PM
vczar1's Avatar
vczar1
Battery light
My battery light keeps coming on and off, batteries were replaced by the dealer and checked out good at advanced auto parts.
Any ideas?
2002 Limited 7.3L
Old Nov 22, 2012 | 04:58 PM
BroncoRN's Avatar
BroncoRN
With vehicle running check voltage at battery. Less than 13.8v and your alternator could be the issue.
Old Nov 22, 2012 | 08:16 PM
xbox73's Avatar
xbox73
Probably built-in voltage regulator on alternator. My battery light also used to flicker very occasionally, and I tied replacing both batteries, cleaning up the battery cable terminals etc., but it still flickered occasionally. Then one drive a couple of miles from home, it was more on than off. And once I saw the voltage gauge 3/4 of the way up stock analog dash gauge e.g. approx 17V? I was worried I might fry the ECM, GEM or IDM, so parked the X once I got home & replaced the alternator & no more battery light flickering since.
2 schools of thought when it comes to replacing - upgrading or replacing with stock rating style from a national branch with lifetime warranty and/or easy replacement.
I initially tried the upgrade path, by buying a 220A rated unit from DB Electrical, which ended up being worse in every way e.g. only 12.8V output at idle, 13.6V while driving & died within 6 months, so I wouldn't advise buying one from them.
When the DB Electrical alternator died, I was in a bind away from home, so bought a NAPA replacement with lifetime warranty (I think), and it outputs ~ 14.4 -14.5V at idle within a couple of secs of starting & when running & is still running fine so far, so I am happier now, though I would still entertain buying a higher rated unit (good for 15k lbs winch, comms radios & stereo with amp etc.), from someone like alternatorparts.com, though I saw someone mention in one of the threads on this forum that they had to make minor mods to their alternatorparts.com alternator or alternator bracket to get it to fit.
2 other points:
- I initially though the NAPA guy had given me the wrong alternator (i.e. the one for the gas truck instead of the diesel) as the alternator was marked with rated output @ 2100 rpm, but that is the alternator rpm, not the engine rpm, which is approximately 1/3rd i.e. 2100 alternator rpm / 3 = 700 engine rpm which is fine for a diesel at idle.
- ever since I had 2 alternators die on me in short order (i.e. the original & DB Electrical, NAPA still working just fine), I really like having a digital voltage gauge. I got this cheap Stinger one from Amazon (
Amazon.com: Stinger SVMR Voltage Gauge - Red Display: Car Electronics Amazon.com: Stinger SVMR Voltage Gauge - Red Display: Car Electronics
), and did the easy trick with popping the top cover off & covering the Stinger logo with electrical tape, so the logo isn't visible. They also make a blue illuminated one, but unfortunately not a green illuminated one to somewhat match the stock illumination. The gauge is small enough that it's easy to find a spot to put it that's easy to glance at, but is still somewhat out of the way so it's not too distracting at night. It's also useful for watching not only the alternator output, but also the battery level when the engine is off to monitor general state of batteries, especially if dry camping & running electrical stuff off the X, and also for watching what voltage the batteries dip to when starting the X.
Old Nov 22, 2012 | 08:36 PM
jh818's Avatar
jh818
You get a voltage gauge with the Scangauge2.
Old Nov 22, 2012 | 08:44 PM
BroncoRN's Avatar
BroncoRN
And the ELM327 bluetooth
bbsitum
1997 - 2003 F150
36
May 2, 2019 09:26 AM
mdr617
1997 - 2003 F150
Nov 10, 2017 12:16 PM
kneescraper
Jan 16, 2012 08:08 PM
badger2196
Jul 2, 2010 02:34 PM
Joe Finn
1997 - 2003 F150
Oct 23, 2006 08:22 PM
