Alternator failed again...
Old Jan 15, 2012 | 09:53 PM
kneescraper's Avatar
kneescraper
1996 F250 460.
My battery light came on and the alt gauge dropped down to 9 volts. I replaced the alternator and it worked for about 60 minutes. Battery light came back on and gauge dropped to 9 volts again.
All connections are good, grounds are good. There is a little black stuff coming out the front holes on the alternator.
Do you think the new part is bad too, or could something be killing it?
Old Jan 15, 2012 | 09:56 PM
deeznuts822's Avatar
deeznuts822
If you did not charge the battery before starting the truck you could have fried it. Or it just could be a bad alt. Ive had them fail in 20 sec bad rebuild.
Old Jan 16, 2012 | 12:23 AM
Hotshot869's Avatar
Hotshot869
Make sure all connections are cleaned, and connected to the right sources as well. A new Alternator shouldn't fail that fast..Something else is going on it sounds like.
Old Jan 16, 2012 | 07:01 AM
critterf1's Avatar
critterf1
If the battery wasn't fully charged you toasted your new alt. Could also be a bad ground or high resistance in the wiring.
Old Jan 16, 2012 | 08:27 AM
kneescraper
Battery was fully charged, grounds are good. The last alternator was there for 8 years. I am hoping it was just another high quality unit from autozone. Everything I get from there takes at least 2 trips.
Old Jan 16, 2012 | 08:39 AM
Weberman3's Avatar
Weberman3
I haven't had good luck with electronics from Autozone.
I usually go to Autozone for all hardware then O'Reilly's for electronics
Old Jan 16, 2012 | 09:25 AM
mpc07005's Avatar
mpc07005
Also make sure your poles are right (+ to +). That would fry your diodes real quick, but I would vote it's the autozone quality. And if you have a 2G, might just want to go ahead and to the 3G swap.
-Mike
Old Jan 16, 2012 | 09:30 AM
rockin300's Avatar
rockin300
i get my alts from napa or car quest
Old Jan 16, 2012 | 10:44 AM
Weberman3's Avatar
Weberman3
If it was me I would get a 130 amp - 3G alternator off of ebay and do the conversion
Old Jan 16, 2012 | 11:16 AM
White 97 xlt's Avatar
White 97 xlt
Just two trips? Dang, you have better luck with their cheap junk than most...
Old Jan 16, 2012 | 07:05 PM
rla2005's Avatar
rla2005
Make sure the Light Green/red wire is hot whenever the key is on:
That wire supplies the turn on voltage for the alternator.
Old Jan 16, 2012 | 07:43 PM
danr1's Avatar
danr1
Dead battery kills an alt?
Alternators job/function is to create power charge/maintain the charge of a battery/ies, having dead or severely low battery or batteries will not kill one unless of course it was junk to start with.
If it could/would do so? Heck I'd have killed the alt in my plow truck 100 times + by now easy. Screw up leave switching valves set to rear, power supply not routed through key.
Well that and everyone ever needed a jump......
Old Jan 16, 2012 | 08:08 PM
mpc07005's Avatar
mpc07005
Severely discharged batteries (like, 8v) can (I stress can) overload the regulator and kill the diodes (depending on the ratings(quality) of the diodes). Many people who need a jump aren't low enough to kill and alt. I see it more often an boats than cars.
-Mike
bbsitum
1997 - 2003 F150
36
May 2, 2019 09:26 AM
Calheader
Nov 19, 2014 02:30 PM
sprint406
37
Feb 21, 2012 06:25 PM
badger2196
Jul 2, 2010 02:34 PM
k150
1997 - 2003 F150
13
Feb 10, 2009 06:47 PM
