Cps or fuel pump?
Old Nov 22, 2012 | 07:04 PM
ReBilld's Avatar
ReBilld
Will UVCH set a CEL?
Old Nov 22, 2012 | 07:08 PM
Action4478's Avatar
Action4478
Yeah , you need to do a buzz test to get the code stored in the IDM ..
Old Nov 22, 2012 | 07:13 PM
Action4478's Avatar
Action4478
There is a cheap test for the UVCH .. When its running bad & the light is on , unplug the valve cover plugs one at a time . one will make no difference in the way it runs . That will be the bad one . There is also a chance you have a bad injector solenoid .. One bad one & the IDM will shut down the entire bank .. Usually it will run well for about 7 seconds then go into limp ..
Old Nov 22, 2012 | 10:26 PM
Redneckmorton's Avatar
Redneckmorton
Ill give it a try if the cps doesn't fix it which I'm hoping it does. I just finally got the truck all fixed up and put back together. I've been driving it off and on for a month now, inspected it yesterday and put a for sale sign on it. And now I gotta fix it before I can sell it.
Old Nov 23, 2012 | 12:11 PM
Redneckmorton
Got the CPS changed out today. And that aint it.
It still wouldn't run after a sec or two. So I pushed the gas peddle all the way to the floor, after a few secs the rpm gauge started to climb and I thought I felt it smoothing out, then I'm starting to think, maybe there is just trash in a fuel line. But I put it in gear and I have no power, it just kinda limps backwards. I let off the gas and it'll idle but rough.
So while it is idling I get out and pull the plugs on the valve cover. Both of them on the passenger side make no difference in the way it runs. Both of the ones on the driver side kill the truck.
I get the truck off the side of the road and into the driveway so I can work on it better. I pull the codes and these are the ones it gives me.
P0113: Intake Air Temperature Circuit High Input
P0500: Vehicle Speed Sensor Malfunction
P0603: Internal Control Module Keep Alive Memory (KAM) Error
Now what do I do?
Old Nov 23, 2012 | 01:40 PM
fordpride's Avatar
fordpride
Pull the pass side valve cover and check the UVCH
Old Nov 23, 2012 | 02:33 PM
Redneckmorton
My dad came by and we were looking at it. He said let me show you something. Pulled the oil fill cap and boom burnt electrical small. Ran to the parts house picked a valve cover casket came home pulled the cover and sure enough the front half of the rear connector was roasted. Threw the new one on and fired her right up.
She's back to purring like a kitten now.
I noticed that none of those codes had anything to do with the like of that issue. Should I be worried about any of them?
Thanks everyone.
Old Nov 23, 2012 | 06:12 PM
fordpride's Avatar
fordpride
Good to hear your up an going
dcelrod
Sep 24, 2014 05:15 PM
curtwalk
May 2, 2007 10:55 AM
Bossman7121
Apr 25, 2007 05:25 PM
hott-rodd
22
Dec 12, 2005 02:49 PM
Wdclark2
May 11, 2005 09:52 PM
