Sponsored by: Real Truck
V10 Engine Knocking problem
Old Nov 20, 2012 | 11:00 PM
rjlawnsnow's Avatar
rjlawnsnow
I have a 2000 F250 SD V10 and i have been having a knock problem for a while. I have replaced timing chains, guides, gears, tensioners the whole bit in the front of the motor. Flex Plate and the torque converter and transmission. I have always maintained my oil changes and im starting to use motorcraft oil filters now. Tomorrow im gonna change the spark plugs...fun task i know i have already done it once before. I have a knocking sound that is there no matter if the truck is cold, warmed up, or sat overnight. it knocks between 1500rpms-2500rpms and once it shifts gears i do not hear it but it does it every gear and i can really hear it if i step on it and left off the gas. oh yea also have replaced the manifolds, studs, and y pipe with jba headers, stage 8 locking header studs and the headers came with a new y pipe. please i need help and i need to decide if i need to get rid of this truck and trade it in to the dealer or sell it. if you can call me im near my phone all the time and would appreciate the help. if you go online at R&J Lawn and Snow, Michigan's Best! my number is on there and it transfers to my cell phone. please do not be a stranger.
Thanks Raymond
Old Nov 21, 2012 | 05:51 AM
redford's Avatar
redford
FTE Leadership Emeritus
Hello rjlawnsnow and welcome to FTE.
Is this an ignition knock (a ping or pre-ignition) or is it a mechanical knock?
Old Nov 21, 2012 | 09:07 AM
rjlawnsnow's Avatar
rjlawnsnow
Sorry i dont know what you mean by ignition knock or pre ignition. It knocks right where the trans and motor bolt up. I can hear it at idle sittiong and knocks whenbi i get to 1400-2500rpms when i drive
Old Nov 21, 2012 | 10:34 AM
Hurricaneowner's Avatar
Hurricaneowner
So it sounds like a diesel truck? You hear a physical "lug lug lug:
" sound?
Old Nov 21, 2012 | 10:45 AM
rjlawnsnow's Avatar
rjlawnsnow
No not a diesel motor sound. Like today i was driving pulling my trailer with two commercial mowers and under load i dont hear it unless i let off the gas. It sounds lije a motor knock but i have not had any loss in power. The knock speeda yp with more rpms the i dont hear it after i shift until i get in the certain rpm range.
Old Nov 21, 2012 | 11:24 AM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
I hate to tell you this but I think what you have is exhaust flutter not a metallic knock, it sounds metallic but it's not it's a resonant sound in the Y pipe that's why it only happens a certain rpms. I had the same sound in my 2000 V10 truck that I still have when it was new and Ford replaced the 2000 Y pipe and with a late production 2001 pipe to fix the problem. I also had a 2000 V10 in a work truck at the same time that had the same Y pipe and it never made the noise but the other one did . All the things you have done with the exhaust so far will just make it worse not better.
Denny
Old Nov 21, 2012 | 12:00 PM
rjlawnsnow's Avatar
rjlawnsnow
Yea but i hear it right at where the motor and trans bolt bolt up. So you think i should get an 01 y pipe and try that?
Old Nov 21, 2012 | 01:59 PM
rvpuller's Avatar
rvpuller
Will you be able to use a standard Y pipe with the aftermarket headers? On ours it sounded like it was at the back of the motor more on the passenger side than the drivers and when we were pulling it was louder. Our sounded like a very very bad lifter or wist pin but I knew it wasn't because it was only during a a certain rpm range about like yours. If you change the Y pipe don't use the rams horn one used in the 99, 00 and early 01 trucks you want the necked down one an if I remember you will also have to change the pipe going to the cat. The only difference between my two V10 trucks was the one that made the noise was a SC DRW with EGR and the other one was a CC SRW without EGR both F350 with 4.30 gears.
Denny
Old Nov 21, 2012 | 02:18 PM
Kdr358's Avatar
Kdr358
This is a mechanical knock, (click the pic to play vid.)
Old Nov 21, 2012 | 02:31 PM
rjlawnsnow's Avatar
rjlawnsnow
Wasnt able to listen to video i dont have a photo bucket account. Can you email me the video
Old Nov 21, 2012 | 02:48 PM
DavidB's Avatar
DavidB
If you can, try to take it to someone with a more "experienced" ear. I have done many, many engine diagnosis/repairs both with rod knocks as well as other problems and I have never had any problem distinguishing a rod knock. It doesn't sound like anything else.
Old Nov 21, 2012 | 03:29 PM
EXv10's Avatar
EXv10
Take a piece of hose and put it to your ear so you can narrow it down and disable the spark one at a time towards the back. Look in the converter area also. We can't diagnose it from here. Take it to a couple garages.
Old Nov 21, 2012 | 05:42 PM
scraprat's Avatar
scraprat
Top Answer: 5
If it's a rod or lifter, it literally has a sound you now that you should get it looked at sooner better than later. I know because I thought I could go just a little further and cost me an engine when part of the #1 intake valve broke and dropped into the engine. It started quiet than over a period of time got just a little louder.
Old Jan 22, 2013 | 01:40 PM
magnessjl's Avatar
magnessjl
This is the same noise my truck is making. what is the cause?
thegreatgate
Modular V10 (6.8l)
May 12, 2024 06:01 PM
erwatt
Aug 24, 2015 11:32 PM
10rowdy10
May 18, 2012 08:16 PM
animal70X7
Jul 21, 2009 12:41 PM
bad69boss
Modular V10 (6.8l)
Mar 22, 2003 08:02 PM
